20 Most Recent
Samsung HL-67A510 67" DLP HDTV Questions & Answers
Where is Fan #1 on a Samsung 67" DLP HDTV
There are 3 fans with this set. Two of them are at top [inner side] and one in the light engine [inside the light engine]. There is no such button to reset the fan only. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Pull up older posts. Surf the site with patience.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done
11/3/2014 4:02:57 PM •
Samsung...
Answered
on Nov 03, 2014
There is a message on
Tv it is not getting the tv stations broadcasting incomming signals.Make sure the ur pay CABLE or free AIR incomming broadcasting tv stations signal sources are good and than go in ur tv menu go into SETUP pick AIR or CABLE and rescan channels again.U should have no more weak or no signal message anymore.
7/8/2014 8:36:42 PM •
Samsung...
Answered
on Jul 08, 2014
SAMSUNG TV
I don't have a schematic for this model. So try this.. .when you open the back of the set, you can readily see two fans, a smaller one on the left, and a slightly larger one on the right. Fan #3 should be behind the larger fan in the front and slightly to the right of it. I would first see if it is operating. You can try to clean it with compressed air ensuring you rotate the fan in its normal direction and don't overdo it. If you can hold the blades so that they are not rotated by the compressed air too fast or at all. You might have to slide the main assembly out to get at it and there should be videos on youtube that show yours or a similar model. Anything further I suggest a trained technician.
7/8/2014 12:14:18 AM •
Samsung...
Answered
on Jul 08, 2014
Can you replace the screen on a Samsung DLP 67a
Yes. The hard part is finding one! the screen itself should not be very expensive as with a flat screen for it is only a reflected surface and as long as the glass on the back is intact, the plastic front can be replaced.
1/16/2014 8:59:25 PM •
Samsung...
Answered
on Jan 16, 2014
White dots samsung hl-s6187w dlp
Your DMD (Digital Micromirror Device) is failing, It roughly has 900,000 mirrors on the chip that move away or towards the light for shading. You may be able to find this board through Shop Jimmy or by simply googling dmd board for your model#
8/13/2012 10:56:33 PM •
Samsung...
Answered
on Aug 13, 2012
My tv only shows in green and purple
Have you examined the color wheel this set should have?look for (remove lamp as it faces that) any segments broken or missing.A color wheel also can have a high pitched or fan like sound but not always.check the wheel first.
6/15/2012 8:06:13 PM •
Samsung...
Answered
on Jun 15, 2012
