20 Most Recent
Speedo Aquabeat MP3 Player i Questions & Answers
Speedo aquabeat 3g mp3 player is not charging.
You are plugging the headphones into the unit and then trying to power up the unit, correct? The Aquabeat will not power up unless the headphones are connected to the unit and disconnecting them will shut the unit off.
My Aquabeat is in a
Hello!
I would recommend you contact your dealer and avail the warranty if it still has.
The type of problem you have can be on the plug of the data cable that you are using to connect your unit to your PC, or there is an open wire on your data cable, or possible that the built-in rechargeable battery is faulty.
If you have other cable that you can use to connect it to your PC and try to charge it, so you could isolate the possibility that the cable is the culprit you may do so.
You have to make sure that this unit has no other activity like LED lit or flashing. Cause if there is other activity, then it could be a file format case that this unit is not supported that causing this unit not to turn on..
I have just brought a
website says the software is not compatible with mac, but it states that when you connect the device to your mac a folder should show up on the desktop and you can just drag songs into that folder
http://help.speedo.com/app/answers/detail/a_id/75/~/how-do-i-use-the-speedo-aquabeat-playlist-editor-software%3F
Can't get the music to play! I charged the player
I do not understand the term "reset"?
Have you checked that you have .mp3 files on it? Try going through the normal procedure at the pc and look at the player like an USB stick. The files should be on the top level.
