20 Most Recent MSI Wind U100-016US Laptop Questions & Answers
I have MSI U100 netbook and my fn key is not working, I have disabled my laptop keyboard and used an external keyboard which doesn't have an fn key. Is there any alternative key for fn? I can'
not really. fn is a laptop only thing. not told what fn , feature you need, but do try usb f1 to F12. alone, see if that works
5/23/2022 2:53:28 PM • MSI Wind... • Answered on May 23, 2022
Some keys of keyboard not working . on MSI WIND
bad keyboard bad cable to it ,inside or loose not told what keys. fail. it needs service in a shop.
5/23/2022 2:50:53 PM • MSI Wind... • Answered on May 23, 2022
Msi u100 bios wont open
Do you have a Windows XP repair disk? Have you looked here: http://www.msi.com/product/nb/U100.html Or try here: http://www.ehow.com/how_5875278_create-windows-xp-repair-cd.html
4/30/2015 9:35:33 AM • MSI Wind... • Answered on Apr 30, 2015
2answers
It says i am connected to the internet but i cant go online
reset your internet explorer
4/21/2015 2:15:14 AM • MSI Wind... • Answered on Apr 21, 2015
Plz help me.... forgot bios password msi mini laptop how to do......plz...
How to Clear BIOS Password Three Methods:Using the Password BreakerReset Jumpers to Clear a CMOS PasswordOther Methods to Clear a BIOS Password A BIOS or CMOS password is set and entered from a DOS-like prompt after a computer is powered on and before Windows or another operating system loads. If you have a computer with a BIOS password, that has been forgotten, or is unknown, you will not be able to get past the password prompt to boot the operating system or even view what is on the hard drive. Fortunately, there are several methods that can be used to bypass it. Learn these methods to find out how to clear a BIOS password.
  • 1
Using another computer, load up your Internet browser. Go to this website, and write down the code shown on the locked computer
  • 2
    • Pay the Small fee, and then enter the code you have written down. A few codes will be provided, so try them all until you find the one that works.This also works for locked HDD drives, so make sure you take a look.
  • 3 You're computer is now unlocked! Keep the backup password handy, this will be invaluable if you locked out of you're pc again.
670px-clear-bios-password-step-1.jpg1 Unplug the computer and remove all peripheral connections like monitors and printers.
  • 670px-clear-bios-password-step-2.jpg2 Reduce electrostatic discharge (ESD). Wear a wrist strap to eliminate ESD, or make sure 1 hand is holding a metal piece while you are working inside the computer. Wear rubber soled shoes, and stand on an ESD mat if possible.
  • 670px-clear-bios-password-step-3.jpg3 Open the computer. Locate the CMOS jumper. The jumper will usually consist of 3 pins, though on the rare occasion, 2 pins (requiring you to supply the jumper itself). This often is labeled with "clear," "cmos," "password" or some abbreviation that indicates it is the password jumper. It is usually located near the CMOS battery, or processor. In laptops, it is often a dipswitch at the bottom of the laptop. Consult your motherboard documentation to find the location if you are unsure of where it is located.
  • 670px-clear-bios-password-step-4.jpg4 Make note of which pins the jumper covers. Remove the jumper. Reinstall it so that it covers the pin that is currently not covered. For example, if it covers pins 2 and 3, change it so that it covers pins 1 and 2.
  • 670px-clear-bios-password-step-5.jpg5 Reassemble the computer, and re-connect the power. Turn on the computer. Check to see that the password is cleared.
  • 670px-clear-bios-password-step-6.jpg6 Turn off the computer. Disconnect the power cord, and open it. Change the jumper settings back to the original position.
  • 670px-clear-bios-password-step-7.jpg1 Search online for generic CMOS passwords. Older computers sometimes have a generic password set by the manufacturer. To find one, search for the name of your manufacturer. Keep in mind that the computer password may have changed or no longer is in use.
  • 670px-clear-bios-password-step-8.jpg2 Download a utility to bypass the computer password. These can be found online and loaded with a CD or floppy disk.
  • 670px-clear-bios-password-step-9.jpg3 Take out the CMOS battery. Leave it out for longer than 5 minutes, and then reseat it. This will clear all BIOS settings, including the password. Keep in mind that you will have to reset the BIOS date, time and other settings.
  • 670px-clear-bios-password-step-10.jpg4 Contact the manufacturer. Find information about the motherboard, and call either the motherboard or computer manufacturer. They can tell you whether there is a CMOS default password or solder beads that must be jumped.
  • How to Clear BIOS Password
    1/14/2015 5:38:27 PM • MSI Wind... • Answered on Jan 14, 2015
    Bad sound for musik
    Are you 12
    9/2/2013 7:37:11 AM • MSI Wind... • Answered on Sep 02, 2013
    My netbook won't turn on at all
    Computer does not boot up The problem maybe the RAM, it could be faulty or just needs reseating to make proper electrical contact. Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
    5/21/2013 9:19:00 AM • MSI Wind... • Answered on May 21, 2013
    Unlock bios password on msi u100
    If the boot sequence is wrong, then how can you even try and log into XP, what you're saying makes no sense.You said, (every time I attempt to log in It prompts me to activate xp)So it's booting to the hard drive, why would you need to change it ??????????????????Removing the CMOS battery might and I mean might reset BIOS password, but that has nothing to do with XP and activation.You can't upgrade until you get XP activated.So you might as well install XP pro.Do a search on google for a XP crack if you can afford to buy it.I won't post how to crack it.
    4/14/2013 2:19:20 AM • MSI Wind... • Answered on Apr 14, 2013
    Will not boot. Get blue screen after booting
    sleeping light always on
    4/7/2013 1:16:46 PM • MSI Wind... • Answered on Apr 07, 2013
    At key wont work i usualy press the shift and the at key together to get the at
    Is another symbol being typed when you press SHIFT+2, then you could have the wrong keyboard layout configured on your Laptop.
    2/24/2013 10:17:46 PM • MSI Wind... • Answered on Feb 24, 2013
    Msi wind smoking from side
    This sounds like the cable from the motherboard to the screen.
    2/2/2013 12:23:16 AM • MSI Wind... • Answered on Feb 02, 2013
    My bios setup is locked with password and i dont know the password,what shall i do?
    The Windows operating system allows you to compress the files on your drive to conserve disk space. In some situations, this compression process will compress files required for the operating system to boot. Files that are compressed must be decompressed prior to execution. Since the operating system has not loaded, boot files cannot yet be decompressed. In this case, the operating system will fail to load and a "BootMgr is compressed" message will appear. An easy way around this problem is to boot from the Windows DVD, and use the provided interface to access your drive properties and decompress it. Turn on the computer, and insert your Windows DVD. Press a random key on your keyboard once you see the "Press any key..." message. This interrupts booting from the hard drive and forces a boot from the Windows DVD. Click the "Next" button at the bottom of the Windows 7 dialog, and then click the "Repair your Computer" link Below. http://windows.microsoft.com/en-US/windows7/What-are-the-system-recovery-options-in-Windows-7 http://msdn.microsoft.com/en-us/library/aa364219(v=vs.85).aspx File Compression and Decompression Select the "Load Drivers" button at the bottom of the "System Recovery Options" dialog, and click the "OK" button on the "Add Drivers" dialog. This opens a file browser on your screen. Click the "Computer" icon, which is located on the left hand side of the screen. This displays an icon for your disk drive. Right-click your hard drive, and click "Properties. " This opens a Local Disk Properties dialog. Click to deselect the "Compress this drive..." option at the bottom, and then click the "Apply" button. Select the "X" icon to close the file browser window. This takes you back to the Install Windows dialog. Press the "X" icon at the corner of the Install Windows dialog. This opens a cancellation dialog. Select the "Yes" button on this dialog to restart your computer. Hope this helps b>
    1/21/2013 7:51:34 PM • MSI Wind... • Answered on Jan 21, 2013
    How to install windows7 over xp
    please click on the link for video step by step demonstration
    12/12/2012 4:53:47 PM • MSI Wind... • Answered on Dec 12, 2012
    2answers
    Will not switch on
    This may be a power supply adapter issue but could be the main-board.
    This also could be a dead battery.
    8/2/2012 4:42:50 PM • MSI Wind... • Answered on Aug 02, 2012
    My model no msi notebook U100 please give me webcam driver site
    Hi this is the link to the MSI Website Wind U100 Download Page, on here you should be able to download all the drivers including the Webcam.http://eu.msi.com/product/nb/U100.html#/?div=Driver&os=Win7%2032
    7/30/2012 10:46:55 AM • MSI Wind... • Answered on Jul 30, 2012
    My msi wind will not
    Hi this kind of behaviour from the MSI mean the battery is dying it is loosing it capability to hold charge so,to solve the problem you should replace it.
    7/21/2012 9:34:24 AM • MSI Wind... • Answered on Jul 21, 2012
    Hi, I am using MSI U100 notebook, having intel atom and windows XP as OS. For the past few days i have a problem and that is my screen resolution is 800 by 600 and i am not able to change to 1024by 80
    If this only started a few days ago why not roll your system back to a date before you started having problems?Click Start/Programs/Accessories/System Tools/System Restore then select a Restore Point (date and time) that is before you started having problems. System Restore will not delete your data, documents, music, pictures, videos or programs (unless the program was installed after the restore point you selected).It sounds like you may have a virus or infection that did something to your display driver, and the restore will take care of it.
    5/10/2012 1:23:21 PM • MSI Wind... • Answered on May 10, 2012
    5answers
    Forgot mypassword
    If you cannot log on to Windows by using a particular user account, but you can log on to another account that has administrative credentials, follow these steps on how to do the trick:
    1. Log on to Windows by using an administrator account that has a password that you remember. You may need to start WinXP in safe mode.
    2. Click Start, and then click Run.
    3. In the Open box, type “control userpasswords2′, and then click OK.
    4. Click the user account that you forgot the password for, and then click Reset Password.
    5. Type a new password in both the New password and the Confirm new password boxes, and then click OK.
    4/3/2012 2:24:49 AM • MSI Wind... • Answered on Apr 03, 2012
    MSI Wind U100-016US 10-Inch Mini Laptop not loading
    It seems like the driver for your installed keyboard has been corrupted or lost. You might want to try a rescue/boot disk to get things going again.
    3/30/2012 7:10:36 PM • MSI Wind... • Answered on Mar 30, 2012
    MSI Wind U100-016US Laptop Logo
    91 questions posted
    Top MSI Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Sean Wright
    Sean Wright
    Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
    View Most Popular
    Wind MSI
    • Wind MSI
    Most Popular Question
    msi wind smoking from side
    • Computers & Internet
