20 Most Recent
Panasonic Toughbook CF-30 Notebook Questions & Answers
Sata drivers xp
For any Panasonic Toughbook built after the year 2005,
if the Toughbook uses a SATA hard drive instead of an
IDE hard drive, then you will need to use Windows XP SP3
(Service Pack 3) instead of XP SP2 (Service Pack 2).
The XP installation CD for SP3 automatically includes
SATA drivers and you do not need any extra drivers.
That is it. Good Luck and Best Regards from:
Richard, Montreal Based Panasonic Canada Authorized
Toughbook Dealer since 1989.
2/5/2018 3:46:06 AM •
Panasonic...
Answered
on Feb 05, 2018
How do i enable touchscreen on panasonic toughbook cf 30ctqazbm
The first thing I would try on any Panasonic Toughbook with touchscreen would be to enter the BIOS upon start-up by pressing the "F2" function key. When you are in the BIOS, there is a setting on the 2nd screen tab "Main" which says "Touchscreen:". This should be set to "Enable" instead of Disable. Then you press the "F10" function key and the message: "Save configuration changes and exit now?". Press "Yes" and the toughbook will reboot and your Touchscreen will be enabled at the BIOS level.
Good Luck!
Regards from Richard, Montreal based Panasonic Canada Authorized Toughbook Dealer since 1989.
11/2/2017 7:20:22 PM •
Panasonic...
Answered
on Nov 02, 2017
Mp light mean
"MP" stands for Multimedia Pocket.
In other words the optical drive or the CD-ROM Drive.
If there is no CD-ROM on your CF-30, this is normal
because when these units were brand-new, the CD-ROM
drive was an optional unit costing hundreds of dollars.
Good Luck.
Authorized Panasonic Canada Dealer in Montreal.
9/11/2017 2:14:21 AM •
Panasonic...
Answered
on Sep 11, 2017
Touch screen dose not work on my CF-30
If your Toughbook has an integrated GPS, this may be conflicting with the touchpad or touchscreen driver. You can fix this by running the GPS Registry Patch - SKIPENUM.REG, which is found in the C:\UTIL\GPS\ folder. This file can also be found by following the link below.If you are using a GPS module that is not integrated, you should contact the manufacturer of the GPS module for a similar patch.If you are not using a GPS module, or if the above steps do not fix your problem, re-install the touchpad and/or touchscreen drivers.
8/16/2016 2:21:58 PM •
Panasonic...
Answered
on Aug 16, 2016
Cf-30 disable touchscreen
On all Panasonic Toughbook Notebooks,
you must get into the BIOS by pressing
the F2 Function key when you turn on the
Toughbook as it is booting. Press F2 repeatedly.
This must be done in the 1-2 seconds before
Windows starts to load. Then you will see
Touchscreen usually on the 2nd page with the
word "Enable". Simply select enable and press
"Enter" and the choice between enable and disable
will appear. Then select "Disable" with the cursor
and then press Enter. Finally you need to
"Save and Exit" the changes in the BIOS.
That is it. Good Luck to you.
Regards,
Richard - Montreal Based
Panasonic Toughbook Authorized Dealer since 1989
4/4/2016 10:39:11 PM •
Panasonic...
Answered
on Apr 04, 2016
Why does my speaker does not work ?
You need to go to Settings on your computer and then go to Sound and check that your speakers are connected to your computer. Also, try to increase volume on your computer. Maybe your volume was turned down.
8/27/2014 11:59:12 PM •
Panasonic...
Answered
on Aug 27, 2014
Panasonic Toughbook won't load Windows XP CD
You can check to see if the hard drive is dislodged, but other than that I don't know what to tell you. If you know the drive is functioning correctly then your motherboard is probably dead.
3/23/2014 11:26:14 AM •
Panasonic...
Answered
on Mar 23, 2014
