20 Most Recent HP Media Center 864N PC Desktop Questions & Answers
I think a virus running real slow
Hello,If it's in the internet browser only and not the whole computer, then try using a different website browser like Google Chrome, Mozilla Firefox or Safari. If the whole computer is slowing down, then run a full anti-virus scan. If no viruses are found, then do a disc clean up. GO to start > Programs > Accessories > System Tools > Disc Clean upDelete all unneccessary files. Just put a check mark on all. After that, restart your computer. Install or update the device drivers - You can use RadarSync to update them all so that you won't miss any outdated driver in the computer. I hope this helps!If you have any questions, please drop me a line.David
2/25/2013 1:25:42 AM • HP Media Center... • Answered on Feb 25, 2013
Hp media centerOn the front of a pc there is a
the HP part # is 5187-2439
1/5/2013 1:16:03 AM • HP Media Center... • Answered on Jan 05, 2013
Why does my hp mediacenter 864n keeps powering off
It may be your memory sticks/cards. I had that problem and took it to the shop and all they did was move the memory sticks down 1 slot. the 1st slot was bad. This will take some detail of removing the skins on the desktop. Hope this helps.Dave
11/16/2011 8:12:33 PM • HP Media Center... • Answered on Nov 16, 2011
Tutoreal recovery con discos
There is a good tutorial here but in English. Maybe use google translate to help you if problems
http://www.pctechbytes.com/hp/hp-recovery
translation from google
No inserte ning?n disco en el HP Pavilion antes de comenzar.Desconecte todos los perif?ricos y dispositivos internos no preinstalado en el PC, excepto el monitor, teclado y rat?n.
Encienda el ordenador y pulse la tecla F1 cuando la pantalla del logotipo aparece por primera vez.
Pulse la tecla de flecha derecha hasta que de inicio se destaca.
Pulse la tecla de flecha abajo hasta Boot Device Priority se destaca.Recuerde que el CD-ROM est? en la lista.
Pulse la tecla Intro, a continuaci?n, pulse la flecha hacia abajo y resalte la unidad de CD-ROM lista.
Pulse el signo m?s (+) hasta que el CD-ROM est? en la parte superior de la lista.
Inserte el primer disco de recuperaci?n en la unidad de CD-ROM.
Pulse el bot?n ENTER para guardar los ajustes y salir. Una pantalla de recuperaci?n parece.
Lea y responda a cada pantalla de recuperaci?n que aparece. Al cambiar los discos, no
pulse el bot?n OK. En su lugar, esperar a que la unidad para leer el disco y que autom?ticamente continuar la recuperaci?n.
Despu?s de la recuperaci?n es completa, restablecer la prioridad de CD-ROM de arranque del dispositivo a su configuraci?n original, de la siguiente manera:
Utilice las teclas de flecha para seleccionar Boot Device Priority en el men? de arranque.
Pulse la tecla Intro, a continuaci?n, pulse la flecha hacia abajo para resaltar la unidad de CD-ROM.
Pulse el signo menos (-) hasta que el CD-ROM se encuentra en su ubicaci?n original.
Reinicie el equipo.
Despu?s de la recuperaci?n del sistema se ha completado, y el equipo se inicia correctamente, actualice el software de la siguiente manera:
Actualizaci?n de las definiciones de virus del sistema.
Obtenga las ?ltimas actualizaciones cr?ticas del sistema con Windows Update de Microsoft.
Actualice el software de HP en el sistema.
3/2/2011 10:04:58 PM • HP Media Center... • Answered on Mar 02, 2011
I have an HP Media Center PC 864n. My PC wont
try to unplug it fromt he back of your pc and open the side of your case and unplug the 2 or 3 onnectors going fromthe power supply and wait 10 or so minutes amnd plug them back in and see if that changes it if it powers back on that meant it has shut off either due to a short circuit and the system killed power to protect the system from damage or the system has overheated
12/11/2010 4:10:03 AM • HP Media Center... • Answered on Dec 11, 2010
0answers
I have erased my sound driver software mistakenly
try doing system restore
11/13/2010 5:29:28 PM • HP Media Center... • Answered on Nov 13, 2010
Disable the Grab Pro and Octh Class add-ons can solve the problem
try firefox! www.firefox.com, way better than IE
9/12/2009 2:24:27 AM • HP Media Center... • Answered on Sep 12, 2009
My ie8 takes forever to load up
I suggest downgrading to ie7 or another brower it's really has some running issuses.
4/18/2009 4:12:32 PM • HP Media Center... • Answered on Apr 18, 2009
Disk boot error
Your Hard drive took a major blow it was enough to send it into a trauma shock replace and do a re installation of the operating system
3/13/2009 9:38:21 AM • HP Media Center... • Answered on Mar 13, 2009
How Do I open The tower
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=us&dlc=en&docname=c00371243
That link is a video of how to take apart yor case. It is very thorough, primarily, it just shows that the side of the case is held on with a couplw of screws, looking at the tower from the front, it's the left panel that you want to remove, not the left, the right one will give you access to what yo are interested in doing.Make sure the plug is removed not just turned off. There is residual voltage that still runs into the main board from the power supply, and try to use a very light computer vacum or one of those swiffer dusters work well. If you poke around with the vacum be careful that you don't **** off the jumpers, you won't relise it untill you turn it on. You can use compressed air that is sold in computer stores or most large electronics stores like Best Buy, Don't forget to get the power supply in thr upper corner of the case, it also has fans in it that collect dust. When you re assemble it, make sure you get the panel in the groove at the bottom, and the clips at the top, and good luck
2/3/2009 5:48:16 PM • HP Media Center... • Answered on Feb 03, 2009
3answers
I need to know how to turn on a HP X13-04657 LAPTOP, all the lights are on but nothing on the screen.
HP X13-04657, is 2007 PC THOSE this PC has CCFL back lamp strip that is dead.Vista era PC, laptops. are hard to work with now, 17 years old.is this not a HP COMPAQ presario HP X13-04657 (wrong name!) sorry !became HP in 2002. so is HP but manuals are super hard to find now. that x13 is part of the microsoft license code vista. (so is distraction to what it is)the real name of the Laptop is and was Presario CQ61 laptop CQ61 the PC has bottom sticker that shows the real names of PCs.CQ61-219TU is real name of on CQ61, there area many different sub codes, and they are not all the same.CQ61-306AX this had CCFL (cold cathode florecent lamps) that love to fail 3 waysdead, blinks ,dime or yellow = white.was made until 2009 and evolved, to LED backlamps.-410 is CCFLI will answer for CCFL as those just love to fail,but the the test is so easynow the answer for ANY laptop this old. 2007 and older. black screen all the time, and BIOS screens dead, answers only me. here. remove the main battery (large) it simply snaps off the bottom.the power pack is next we run the PC on your power pack AC to DC it must make the screen glow with something, do not use the wrong pack as in mixed up with others.now the lap top seems on, even the fan blows, LED glowpoint a flash lamp at the screen ,dark' room , and of you see any kind of LCD data on the screenthe CCFL lamp below #1 is bad.this is phase 1 testing, as other things can fail too. The keyword below is Mercurythis tells me it is those pesky CCFL glow tubes. 2007 is the year some PC went to LED back lamps. yes I was correct the service manual I did find proves they made both lamp types ccfl-hp07-psnmcz4s4yabbrmds04n13cd-d-0.jpg
4/17/2024 12:37:57 PM • HP Computers &... • Answered on Apr 17, 2024
Dove posso scaricare il driver per HP ScanJet 8270? ente compatibile per windows 10...
Question edited for clarity. Question translated to English. We only speak English on this North American website. https://www.google.com/search?q=hp+scanjet+8270+driver+windows+10
HP Scanjet 8270 Document Flatbed Scanner
Hewlett-Packard https://support.hp.com > ca-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner ... drivers free of cost for Windows and Mac ... Windows 10 / ...
Hewlett-Packard https://support.hp.com > ee-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner. This is HP's official website to download the correct ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Download
Softonic https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.softonic.com Download the latest and official version of drivers for HP Scanjet 8270 Document Flatbed Scanner. This driver package is available for 32 and 64 bit PCs. It is ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Free ...
Download.it https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.download.it Download HP Scanjet 8270 Document Flatbed Scanner drivers varies-with-device. Software drivers for the 8270 flatbed model of the HP Scanjet printer. ..
4/10/2024 8:38:39 PM • HP Computers &... • Answered on Apr 10, 2024
2answers
HP 8440P Laptop. I don't remember my password. Help needed for HP 8440p.
This video shows you what to do if you forget your computer password:
4/6/2024 8:00:24 AM • HP Computers &... • Answered on Apr 06, 2024
2answers
How to do a bios recovery on a hp pavilion dv5-1004nr
This video shows you how to restore the BIOS in your computer:
4/6/2024 7:57:59 AM • HP Computers &... • Answered on Apr 06, 2024
Hp dv8 not charging battery
You can follow the steps in this video to troubleshoot your battery:
4/6/2024 7:13:37 AM • HP Computers &... • Answered on Apr 06, 2024
Hp supply central pin connected to the 19V power
  1. Central Pin: In many laptop power supply connectors, especially those using the barrel-type connector, there's a central pin that carries the voltage (typically around 19 volts for most laptops) to power the device.
  2. Voltage and Polarity: It's crucial to ensure that the voltage supplied by the power adapter matches the requirements of your laptop. Most laptops operate on 19 volts, but there are exceptions, so always double-check the specifications of your laptop and the power supply.
  3. Polarity: Additionally, the polarity of the connector is important. The central pin typically carries positive voltage, while the outer sleeve of the connector is the ground (negative). Reversing polarity can damage your laptop, so make sure the connector is inserted correctly.
  4. Safety: Always use the power adapter that came with your laptop or a compatible replacement from a reputable manufacturer. Using an incorrect or incompatible power adapter can not only damage your laptop but also pose safety hazards such as overheating or electrical fires.
  5. Replacement: If you need to replace your laptop's power adapter, ensure that the new adapter provides the correct voltage, polarity, and wattage for your laptop model. It's often safer to purchase adapters from the laptop manufacturer or certified third-party suppliers to guarantee compatibility and safety.
3/30/2024 8:53:24 PM • HP Computers &... • Answered on Mar 30, 2024
3answers
I got a 4 year HP laptop and it show a black screen and if I press Esc it will say Esc..start up and will do the same F2 and others.
If your laptop starts but the screen remains black, this video shows you the troubleshooting steps to follow:
3/27/2024 7:16:54 AM • HP Computers &... • Answered on Mar 27, 2024
What kind of screws open the backside of an HP Envy PC
The screws are T5 Torx security screws. You can get a set of these screwdrivers from any DIY Store or from Amazon. https://www.google.com/search?q=torx+screwdriver+set I have a set like this which has a handle and all the security screw bits. https://www.canadiantire.ca/en/pdp/mastercraft-33-pc-torx-screw-set-0544039p.0544039.html ..
3/13/2024 5:33:03 PM • HP Computers &... • Answered on Mar 13, 2024
How do I open the back of an HP Envy PC, and What kind of screws open the back please.
Great questions, but two questions edited into one. The screws are T5 Torx security screws. You can get a set of these screwdrivers from any DIY Store or from Amazon. https://www.google.com/search?q=torx+screwdriver+set I have a set like this which has a handle and all the security screw bits. https://www.canadiantire.ca/en/pdp/mastercraft-33-pc-torx-screw-set-0544039p.0544039.html ..
3/12/2024 6:00:48 PM • HP Computers &... • Answered on Mar 12, 2024
HP Media Center 864N  PC Desktop Logo
15 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
tutoreal recovery con discos
  • Computers & Internet
