20 Most Recent
Speed Queen AWS76NW Top Load Washer Questions & Answers
Unbalanced Load Light
I don't know if this is a new washing machine or not, but I would recommend is getting a few small thin boards and making sure the machine is level. If this doesn't work there could be a bad sensor, but that doesn't seem like the case to me as moving the machine a little gets it to restart.
Speed queen washer shown er65
The Speed Queen error code 65 occurs when the washer's main control board detects a problem with the door switch. The door switch is a safety feature that prevents the washer from operating when the door is open. When the main control board detects an issue with the door switch, it will display the error code 65. There are a few reasons why the door switch may be malfunctioning. The most common reason is that the door switch is dirty or obstructed. Another possibility is that the door switch is loose or damaged. If the door switch is damaged, it will need to be replaced.
Speed Queen Washer displaying codes TL 05. 00 D5
Yes, good diagnostics and summary. Don't guess with control boards for exactly the reason you stated. Call for service, you need the correct diagnosis and warranty on the part and the service call. There are indeed expensive and not for guessing.
Speed Queen SC30BC front load single phase 240 volts washer.
To diagnose the issue with the Speed Queen SC30BC washer, it's important to determine which component is causing the fuse to blow. Here are a few steps you can take to help identify the problem:
- Unplug the washer and visually inspect the wiring and components for any signs of damage, such as frayed wires or melted components.
- Check for any loose connections, and tighten them if necessary.
- Use a multimeter to measure the resistance across the wiring and components. If the resistance is very low, it may indicate a short circuit.
- Check the drain pump for any blockages or damage.
- Inspect the control board for any signs of damage or melted components.
- Test the door switch to make sure it is functioning properly.
- Test the water level control valve to make sure it is not stuck open and allowing excessive water into the washer.
If you are not comfortable with electrical repairs, it's best to call a professional for assistance. Attempting to repair electrical equipment without proper training can be dangerous and potentially damaging to the machine.
Speed queen washing machine model number awne82sp11two1 stuck on cycle
If your Speed Queen washing machine is stuck on a cycle, there could be a few different issues causing the problem. Here are a few things you can try to troubleshoot the issue:
- Check the power supply and make sure that the washing machine is properly plugged in and receiving power.
- Check the fuse or circuit breaker to make sure that the washing machine is not tripping any electrical circuits.
- Make sure that the washing machine is not paused or paused on a cycle that is longer than usual. If the machine is paused, simply press the start button to resume the cycle.
- Make sure that the washing machine door is properly closed and latched. If the door is not properly closed, the machine may not start or may get stuck on a cycle.
Speed Queen Awn412sp111tw01 Washer, no cold water!
In the back of the cold water hose connection there is a small gauze filter. Check is is clear of limescales and debris. While the hose is off, hold the hose in a bucket and have someone else turn the stop valve on. Don't try and do it yourself. If you have good water flow and a new water inlet valve, it can only be the wiring or the control board / connections to it.
My speed queen will keep running through all cycles and now it full and won't drain.....please help
The drain pump is clogged or not working. Some washers have belt-driven pumps - check the belt. If it is practical, unplug the washer and try turning the pump by hand (with the belt removed if it has one). If you can't turn it in either direction, it is jammed up or the bearing has seized.
If you need help identifying the pump, look online for appliance parts for your model. Most online dealers will have photos of the parts. The pump will be somewhere in the drain line from the tub to the drain hose.
