20 Most Recent
Frigidaire FWS933F Top Load Washer Questions & Answers
I put in a small load, started the washer , and
there is a water level sensor that you set by the water level required for the wash
when that level is reached it turns off the inlet solenoid and progress to wash cycle
you problem is a faulty inlet water solenoid /control or water level sensor
call in a technician to check the small hose to the level sensor or the flow control valves
My frigidaire top loader fills with water at the
Hi, could be your timer motor, timer or water level switch, first push timer knob in and manually advance to wash or spin cycle (program) then pull knob, see if machine operates, let me know, then i can tell you exactly what's problem.also advance timer, to spin cycle (program) machine should pump out water, or you can lower drain hose into bucket and empty machine, you should empty machine and try again, let me know what happened, we can solved this together. good luck.
My washer quit getting all the water out of my
Hello, Thank You for using FixYa. I will be helping you today. Remove the two screws in the lower corners of the front panel and push down on the panel and remove.You will see the belt there.
Thank You and please rate my answer if it was helpful..
Frigidaire MWX233RES4, Washer drains but does not
If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Smells like smoke and my clothes are still wet
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
The water level on my FWS933 does not fill all the
Check the water pressure switch. You can trace this switch by following a small water hose running into this switch. See whether any adjustmnents present. ( just a guess only- as there are many designs )
My Frigidaire Affinity washer makes a loud buzzing sound when you push the start button and will not start, what can I do
Good Morning Anonymous, this is Z. I am happy to assist you!
I understand that your door indicates it is open and your dryer will not operate. Let's attempt resetting your dryer by either unplugging it or flipping the household circuit breaker off. It is good to wait approximately ten minutes and turn on your dryer. Select a normal cycle and verify if your dryer will start. If your dryer will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. At this point, it would be advisable to contact an experienced appliance repair tech to assist further.
