20 Most Recent
Fisher and Paykel WL26CW1 Top Load Washer Questions & Answers
Fault 240 wl80t65cw1
240. (11110000) Hall Out Of Order. RPS Fault
Same as previous Hall Error faults See fault code130 for directions.
130. (10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness between the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: Check for corrosion on the RAST connector of the Rotor Position Sensor and the Motor Control Module connector.
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted
Fault 9 flashing on wl26cw fisher and paykel washer
Fault 9
LAH HIGH CURRENT FAULT
The low ambient heater is drawing more current than expected. Either the heater or wiring is faulty.
Primary Action
- Check the wring and connections at both heater and power module.
Secondary Action
- Check heater resistance. If not within limits replace heater.
Washer icons won't show up and washer sparks at plug when I plug it in.
If the plug is fused then the fuse should blow before an appliance catches fire. If you go here they have a great customer service base and can recommend an authorised agent to look at and repair your machine if needed. If you want a manual they can also supply you with one just to make you more confident about the operation of your machine.http://www.fisherpaykel.com/us/laundry/?productUid=49343ABD-C773-932B-26D02C8672FC7E2B
