20 Most Recent Whirlpool Inglis IP4400 Washer Questions & Answers
I have an inglis type
Search "Whirlpool Direct Drive Cabinet", or just have a look at this: How to Disassemble Whirlpool Kenmore Direct Drive Washer
1/31/2018 9:11:37 AM • Whirlpool Inglis... • Answered on Jan 31, 2018
2answers
I just moved and the
If your line is not frozen and cracked then it's the water control on the back of your washer where your main water hoses screw into the washer. Check this water control because it is plastic.
10/22/2017 1:31:01 AM • Whirlpool Inglis... • Answered on Oct 22, 2017
I have an inglis im42201 washer won t spin
Definitely could be the clutch. It should be very hard to move clutch pad Assembly inside metal housing. . If not that, the basket drive- the part with the brake on it - needs replacing.
9/9/2017 12:09:37 AM • Whirlpool Inglis... • Answered on Sep 09, 2017
3answers
INGLIS WASHER SUPERB AGITATOR DOES NOT WORK
sorry not real solution as I am not familiar with that design but recommend replacing machine.
9/12/2016 9:07:58 PM • Whirlpool Inglis... • Answered on Sep 12, 2016
The lock keeps locking and turning the washer off
LID LOCK LIGHT STAYS ON NO START: Usually either the lid lock mechanism, the lid lock actuator or the board is the culprit even a disconnected capacitor. MACHINES SAIDS SENSING When the START button is pressed, the washer will first perform a self-test on the lid lock mechanism. You will hear a click, the basket will make a slight turn, and the lid will unlock briefly before locking again. Once the lid has locked the second time, the washer will slowly spin the dry load to estimate the load size, and begin adding water. The washer will then move the load briefly, pause to allow water to soak in to the load, and resume adding water. This process may repeat until the correct amount of water has been added for the load. You may also hear water flowing through the dispenser, adding detergent to the load. NOTE: The sensing light may also come on during the Soak and Wash portions of the cycle. This is normal. Try unplugging the cord a couple of times. See what happens then try going into diagnostic error codes, see what codes are shown. To pin point where the problem is. if you have no display to read the fault codes. Your main control board may be the issue. Next, while in Manual diagnostics, try to get the unit to spin; if the motor hums for a split second and then shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors. This is proof that the shifter/sensor actuator assembly is the issue because the optical sensor is not reading the motor speed. I suggest unplug the washer and check the wire connections on the switch. If a meter is available then you can check the resistance (ohms) of the lock motor. Note: After performing the manual test and the lid lock works perfectly, or at least as it is supposed to. You can eliminate that as the problem.If the lock worked in the manual test but doesn't in an actual cycle then I suspect the control board is at fault. A safety feature found on front load washing machine is the door switch and the door lock and strike. On most models, the door switch must be closed and the door lock must be activated before the washer will start. The switch is normally located in the door frame of the washing machine, but may also be part of the door lock assembly. Inspect the strike to make sure that it engages the door lock assembly and that the door remains closed. To check the door switch for continuity with a multi-meter, you will need to disconnect the power and remove the front panel. The lid switch on a top load washing machine is a safety device designed to prevent the motor circuit from operating when the lOn some models, the water inlet valve circuit is controlled as well. If the lid switch fails, the washer may not start. The lid switch is normally located beneath the main top with a projection on the lid or a pin attached to the lid that will actuate the switch when the lid is closed. Verify that the switch is being activated mechanically and that any levers or actuators are not damaged or sticking. If the switch is being activated but there is no power being supplied to the motor or water valve circuits, then the switch may be defective The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in God is good and that's why I give free advice. lock-keeps-locking-turning-washer-off-y0uj30y2msg4iwsg11dgquj1-5-0.jpg lock-keeps-locking-turning-washer-off-y0uj30y2msg4iwsg11dgquj1-5-2.jpg lock-keeps-locking-turning-washer-off-y0uj30y2msg4iwsg11dgquj1-5-5.jpg lock-keeps-locking-turning-washer-off-y0uj30y2msg4iwsg11dgquj1-5-9.jpg lock-keeps-locking-turning-washer-off-y0uj30y2msg4iwsg11dgquj1-5-14.jpg lock-keeps-locking-turning-washer-off-y0uj30y2msg4iwsg11dgquj1-5-20.jpg
5/31/2015 9:06:57 PM • Whirlpool Inglis... • Answered on May 31, 2015
Why does my washer overflow and not agitate?
Washer fills with water and overflows: The water pressure level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective. You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube. If the machine starts to wash. the pressure switch is more than likely good ( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED). The other item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board.
4/4/2015 3:28:06 AM • Whirlpool Inglis... • Answered on Apr 04, 2015
Laveuse inglis cogne
1 pillow.
2/12/2015 11:14:26 PM • Whirlpool Inglis... • Answered on Feb 12, 2015
My washer spins rinses but wont move in wash cycle
ok when you turn ur machine to wash and start can you hear any sounds wait a few mins if so then it could be a water valve on the machine and u could do this ur self
2/4/2015 9:41:45 PM • Whirlpool Inglis... • Answered on Feb 04, 2015
My Inglis by Whirlpool washer doesnt spin. Its a Direct drive unit so Im guessing that the clutch is bad?
does the motor run when its supposed to spin? if not its probebly a lid swich problem. if the motor runs it may be a coupler or poss. cluch. sometimes a sock in between the tubs. If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
2/2/2015 10:34:38 PM • Whirlpool Inglis... • Answered on Feb 02, 2015
0answers
My inglis washer wont cycle
What is the model number of the unit?
11/15/2012 12:05:42 AM • Whirlpool Inglis... • Answered on Nov 15, 2012
My washer does not cycle, what do i do
What is the model number of the unit?Could you please describe the problem you are having a little better?
11/15/2012 12:04:07 AM • Whirlpool Inglis... • Answered on Nov 15, 2012
Whirlpool Inglis IP4400 Washer Logo
165 questions posted
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
View Most Popular
  • Whirlpool Washing Machines
Most Popular Question
whirlpool inglis dead
  • Washing Machines
