20 Most Recent Whirlpool WTW6400SW Cabrio Washer Questions & Answers
Hi
Thanks for using FixYa. Yes you are right you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Error F1 means primary control failure and to resolve this you’ll have to replace the machine control assembly. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Whirlpool... | Answered on Feb 26, 2019
Typical sequence: power on, lid locks, then unlocks, then locks again and should stay locked the 2nd time. If not, depending on model and design, actuator may need replacing that shifts transmission from agitate to spin.
Whirlpool... | Answered on Dec 19, 2018
WHIRLPOOL CABRIO WASHER ERROR F2
The Cabrio Washer F2 error happens when the main control detects a stuck key on the user interface. The steps to take to try and fix the F2 code problem are below:
Unplug the washer for five minutes and then plug it back in, this will reset the control board.
If the persists then the only way to fix it is to replace the user interface board.
Whirlpool... | Answered on Nov 06, 2018
Bruce:
Thank you for your review.
We would like to inquire further about your review with you. Please respond back to this email address, Whirlpool_Reviews@Whirlpool.com, with your name, phone number, street address, zip code, model & serial number, and date of purchase on the appliance.
We look forward to your reply.
Thank you,
Whirlpool® Social Media Relations
Whirlpool... | Answered on Mar 09, 2018
Hi valued Consumer, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Valued Consumer), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Whirlpool... | Answered on Apr 25, 2017
If you are getting ripped or torn clothes then most likely they are getting bunched up underneath the center piece that turns. These usually go back and forth and not all the way around in order to keep from bunching and tangling. It may be getting caught up on a lose bolt or something inside and under the center piece. If you can't figure it out just get a new one and part that one out or sell it at a garage sale. The electrical board and dials alone are worth a hundred bucks to the right buyer.
Whirlpool... | Answered on Jan 12, 2017
using to much soap run washer water only in shortest cycle then cut your soap use in 1/2
Whirlpool... | Answered on Jan 02, 2017
it is extremely unlikely that clothes have got to the position you mentioned
unbalance comes from
1--- clothes out of balance in the tub--too much on one side
2--machine not level on the floor --- rubber feet missing from adjuster bolts
3-- suspension rods and insulators for the tub broken or missing
these suspension rubbers/ plastics break on a regular basis and allow the tub to sit at an unlevel state causing an unbalance situation when spinning
top covers are either held in place with screws at the front and back ( under plastic trim buttons ) or simply clip on to the side walls at the top
talk with a service agent as to how to remove the top or download a workshop manual for the machine from the net
Whirlpool... | Answered on Oct 29, 2016
The machine has detected an overload.
Whirlpool... | Answered on Aug 15, 2016
  1. Ft. Cabrio Top Load Washer‎
    Adwww.sears.com/‎Black Friday Sale Save Over 40% on Select Appliance
    Hot Buys. Free Delivery Over $399.
  2. Appliance Hot Buys
    You'll Save More When You Shop Hot
    Appliance Buys on Select Products!
Search Results
    Whirlpool WTW6400SW Cabrio Washer Makes clicking ...
    www.fixya.com > ... > Whirlpool WTW6400SW Cabrio Washer
    Whirlpool WTW6400SW Cabrio Washer, makes clicking noise spin cycle related issues. Get free help, solutions & advice from top Whirlpool experts.
Whirlpool... | Answered on Aug 10, 2016
LF generally means "long fill error," which is generated when your washer is not getting the correct amount of water. This could be because of a clogged inlet screen, a leak which is causing low water pressure or a faulty inlet valve. You may want to contact Whirlpool for instructions on checking or replacing your hose, or cleaning the inlet screen.
Whirlpool... | Answered on Jun 29, 2016
dump a box a baking soda in it and run empty . see if it helps your problem
Whirlpool... | Answered on Jun 22, 2016
Whirlpool WTW6400SW Cabrio Washer Logo
388 questions posted
Marvin
Marvin
Gerry Harvey
Gerry Harvey
View Most Popular
  • Whirlpool Washing Machines
Most Popular Question
f 2 code mean cabrio platinum washer
  • Washing Machines
