initially unplug the device for 10 minutes from main outlet and then plug back in and then check wether it works.
otherwise:
It doesn't work at all
If your washer doesn't seem to work at all, check these:
No powerLid switch
No power
Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
thanks and plse do not forget to accept this solution.
