20 Most Recent
Samsung WF206ANS Front Load Washer Questions & Answers
I just got my pump replaced and now i need to reset my samsung washer it still shows nd and stops
The problem is probably in the control panel or water level switch. I just posted a procedure to clean the relay contacts for the pump motor relay. This little relay is on the control circuit board and is not normally customer accessible. But the alternative is purchasing a new control circuit board (which in my case was not available) or replacing the washer. Please refer to my solution for the problem "Drain Pump doesn't work" posted today.
What size of belt do i need for a two pulley deck 38 inch cut
If the belt is broken , lay it flat and measure it. Take 1/2 inch off for stretch and get a new one at that length. If you can't read the numbers on the belt and it isn't broken, mark the back of the belt and measure the belt from one side of the mark all the way around the back of the belt to the mark again. Do the stretch 1/2 in and get the new belt size that way.
Door wont open
Turn on a cycle and wait for it to start. should fix the problem
How to change belt
Check the belt at the back, there is a small compartment where you will have to take off 4 screws and a door. Otherwise check the inside of the tub and the drum. Something maybe caught in between.
Error message of
That means overflow. There is too much water in the drum. Turn the unit off and it should drain. If not then it might be a sensor that is bad.
A "nd" code displayed,
How to fix a Samsung Washer nd washer error code. You can make this repair your self and in most cases without parts. Let me explain what the nd on a Samsung washer control panel means exactly. The nd error code stands for No Drain. When this washer error code comes up the washer will not spin either.To fix this issue you will need to slide the unit forward to access the pump if there is no access panel on the lower front. If the clean out access panel is on the lower front bail the water from the washer and twist the filter head counter-clockwise. If the front panel does not have the access panel the washer will need to be slide forward. With the washer pulled out the back access panel can be removed. With the panel removed, the drain pump will be visible. Remove the two hoses on the pump followed by the two 7/16 bolts that mount the pump down. With the pump off, you can now remove the debris inside.Put the washer back together and test for proper operation. If the error code comes back this means that the pump is clogged again or the pump has failed and would need to be replaced
