20 Most Recent Frigidaire GLTF2940F Front Load Washer Questions & Answers
Check with your appliance parts repair people in your area.
You should find no one will touch the electronic control panel. Usually, the time it takes and the cost for diagnostics will negate any profit for the business.
Same as why many cars must go back to the dealer for electronics. Most of your local repair people will just replace the board.
God bless your efforts.
Frigidaire... | Answered on Jul 07, 2017
washer stopped working, displayed E5E error when prompted for code. I opened up the back of the machine and noticed that a connector was not connected to the control board, i removed the control board to get a better view of where it belonged, and slid the connector over the control board, closed up the machine and it's back in business.
Frigidaire... | Answered on Jul 23, 2015
Good Afternoon Friend,
I understand you want to remove the paneling on your Frigidaire washer, model# GLTF2940F, to work on your machine. Typically, this is not a do it yourself action, as there are no step by step instructions on how to remove the paneling. I suggest either contacting the manufacturer or your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
Frigidaire... | Answered on Jul 01, 2014
Good Morning Friend,
I understand you are receiving an E62 code on your Frigidaire Gallery washer, model# GLTF2940FS2. The E62 code means that there is a communication problem between the different control boards in your appliance. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Frigidaire... | Answered on Jun 30, 2014
CONTROL penel error
Frigidaire... | Answered on Oct 22, 2013
Hi
Error code e20/e21 means a clogged drain pump. This might have happened due to small clips, pins, coins, etc being stuck in the pump. Please note that error e21 can also occur when the drain pump is not pumping fast enough or when the pump fails. To fix the issue you'll need to check the drain pump.
Remove the 2 screws from the bottom of the front access panel, it will come off. Now check for the pump on the right side and remove hoses from it. Remove pump from machine then remove whatever is there in the pump. Hope this helps... Please post back for any further assistance.
Frigidaire... | Answered on Sep 29, 2013
Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage, then check pump. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the front access panel, and remove the clamp that connects this trap assembly to the pump and clean it out.
If helped pl say so, thanks.
Frigidaire... | Answered on Apr 02, 2013
If the door lock engages then you have a bad water inlet valve. Here is a link to the part.
Frigidaire... | Answered on Oct 17, 2012
E41 Control board thinks the door switch is open.
In the J2 plug on the control, measure voltage from the black wire to ground with power on.
0 volts. Check the door strike. If good, replace the door switch assembly.
120 volts. Replace the control board.
Frigidaire... | Answered on May 12, 2012
Check your drain hose to make sure its not kinked or clogged. If OK try the other washing selections If same on all wash cycles. The pump is not performing correctly
Frigidaire... | Answered on Feb 19, 2012
Hi.
You need to check the drain filter, which is directly connected to the pump. That is the place where you usually find blockage. The filter or coin trap is located inside the drum. See the schematic below:
If that is not enough, then the drain pump access is located in the front side of the machine, hidden behind the trim at the base. The kick panel is held to the washer's frame by screws:
After removing the panel you will Be able to access the pump. Have a container ready to collect water that will come out through the hose.
DISCONNECT POWER before starting the job.
Here parts diagrams:
GLTF2940FS1 - parts catalog
Here a page about drain/spin problem.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Frigidaire... | Answered on Sep 10, 2011
Turn the machine off then unplug it for at least 5 minutes then plug it it back. Turn on the washer then press any button and wait for 5 seconds. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the most recent failure code will appear on the display as an "E" followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. Post back the error code, if there's any, for further troubleshooting and repair advice. Indicate the exact model number of the machine if the procedure prescribed here is not applicable.
You don't have to accept or reject this post in order to add comment or information. But accepting the solution should you find it helpful and/or informative will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Frigidaire... | Answered on Jul 27, 2011
Frigidaire GLTF2940F Front Load Washer Logo
64 questions posted
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Washing Machines
Most Popular Question
won 39 t drain blinking pause
  • Washing Machines
