20 Most Recent
Frigidaire Affinity ATF6000F Front Load Washer Questions & Answers
Affinity ATF6700 washer has 'err' in display, I can't press any buttons, unplugging it did nothing.
Question edited for clarity.
Question moved to Affinity.
Try a full system reset. If that doesn't work, you need a service call.
Resetting the Frigidaire Affinity washer
- Unplug the power source or turn the circuit breaker off for a few seconds.
- Then plug the power back on to reset the washer to default settings.
- Now press the cancel button to cancel all commands.
- And in the next step press and hold the spin speed and soil level buttons together for four to eight seconds.
- Hold the buttons until you hear some signal sounds and then leave the buttons.
- After that open the door for more than 2 times and make sure it gets closed again each time. After this, your machine has been properly restored to proper default settings. This will lead your machine to work properly again.
What does error code E-11 mean
Hello Roger, thank you for your inquiry!
Based off the information you have provided you would like to know what an E-11 error code means on your Frigidaire washer. An E-11 error code means that the fill time is too long. This could be a possible problem with your pressure sensor, water valve, or main control panel. If the water pressure is below 30 PSI then it will continue to display the error code of E-11. Also make sure the hoses are not restricted or blocked because this could cause the error code to display. I hope this information has been helpful to you. -Matt
Why does my washer leave black hole marks
Hey friend, thank you for your inquiry!
I understand that your Frigidaire washer is leaving black hole marks in clothing. This could be caused by internal issue with your tub or something could be caught along your tub causing the holes. You may want to look inside of your tub for any visible issues that could cause holes in your tub. You can also use a suck or pair of panty hoses to see if there are any issues with the tub. Place the sock or hose on your hand and rub it along the inside of your tub this will let you know if clothing is getting snagged on anything. If you continue to have issues with your washer I would recommend contacting a professional for proper diagnosis and repair. I hope this is helpful. -Matt
How do I fix my washing machine
Hello carl2892, thanks for your post!
From what you have described your washer is leaving water in the bottom and will not spin. It sounds like you might have a possible drain pump failure or issue within your control panel. I would recommend performing a reset on your washer and you can do that by flipping the household circuit breaker off for roughly ten minutes. If that does not help resolve your issue I would suggest consulting with a professional technician for proper diagnosis and repair. Hopefully this information is helpful. -Matt
How do i get code for my affinity washer
Hi - Could you please press and hold the start/pause and cancel button together at the same time for approximately 30 seconds? What error code does it display? With this information I can assist you further with the issue that the washer is having.
Why does my frigidaire affinity front loader not start but gives error message or pau message. It acts as if I have pushed the start button once chen I first close the door because it lights up before
Good Morning Laurencemcna,
I understand that your Frigidaire Affinity washer, model# ATF6000F, does not start, but instead, gives an error code or "PAU" message. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power, and try to start your washer again. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
What does error code 64 mean?
Hello Friend, this is Z. Thank you for allowing me to assist you!
An error code E64 is associated with the heater circuit in the open position. A technician would typically check the heater coils and connections for short circuits to the cabinet to determine if this is the cause of the error code. Depending on the readings, the heater and/or wiring will possibly need replacing. This is not a normal DIY job so you may want to connect with a local servicer to determine the exact diagnosis to help reduce the risk of unnecessary parts. I hope this helps explain the error code you are receiving.
Why is my washer displaying a "DR" when I push start?
Press any button on the display panel.
Wait five seconds and then press and hold the "Start/Pause" button and the "Cancel" button at the same time.
Open and shut the door. A "DR" error code indicates that there is a problem with the door, most likely that it has not shut properly. Check to make sure there are no clothes or other items caught in the door.
Open the door and gently wiggle the door latch if the door does not click shut. Clean it with a damp cloth to remove excess dirt or debris that may prevent the door from latching into position.
5
Close the door and re-select a new wash cycle and "Start."
Code E 21 Error on Affinity Washer Front Loader
I've had problems starting my washer because the door does not close properly, and then I get an error or pau code
What has worked is to unplug the washer for a minute, close the door, and then plug it back in. it then starts normally with 2 pushes on the start button
Why is paint comming off conrtols for 3 month old new oven
Good Morning Friend,
I understand the paint is coming off the controls of your 3 month old Frigidaire oven. I suggest contacting the manufacturer directly for further assistance. They should be able to help resolve this the best. Hope this is helpful.
-Best Regards-
WP
What are the cubic feet for the affinity atf6000fs1
Hello Friend, this is Z. That's a great question!
I show that your Frigidaire Affinity washer (ATF6000FS1) has a total capacity of 3.5 cubic foot. Hope this helps! If there is anything else that I can help you with, please feel free to reconnect.
