20 Most Recent
SVP Xthinn 8061 Digital Camera Questions & Answers
How do I turn it on ? I dont see an on or off
Does this camera have a slide front that covers the camera lens? If so, sliding the cover to expose the lens is what turns the camera on. If it won't turn on, maybe it needs attention to the batteries.
My camra will not allow
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
CHARGER
u can use USB cord to charge for temp only dont use usb cord for charging for long time
How do i get my svp xtinn-8061 web cam to work
1. Install the camera driver, which can be found from the CD.
2. Turn on the Camera, and change it to "Playback" mode.
3. Connect the camera to the computer using USB port.
4. The LCD display of the camera will turn off automatically, and the computer should say that new hardware is detected.
5. Go to "My Computer", and you should find a new drive saying "Removable disk".
Double click it and you should find your pictures and videos inside the folder. Just copy them to your computer's hard disk.
Connecting to a Vista Computer
Having problems connecting the camera to a Vista computer?
Double click it and you will find your pictures and videos inside the folder. Just copy them to your computer's hard disk.
Can't connect to vista
Try this.
Hope that helps.
