20 Most Recent
Rokinon DC59 Digital Camera Questions & Answers
Manual for a rokinon for DZ880
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
Need user manual
This manual apparantly, isn't available on the net, and other experts have searched, without success. Any chance of finding the manual will have to be from Rokinon support. Since they don't seem to have a web support site, you will have to contact them through the literature that came with the camera.
Wish I had more suggestions, but this appears to be the only shot at getting one.
Can i download a guide for my power zoom DZ980
I have spent over an hour searching for a manual. Since the manufacturer doesn't seem to have a website, I thought maybe one could be found on other help sites. I came up empty. I did find other users searching for manuals but they came up empty as well. Sorry I couldn't help.
TRYING TO CONNECT
Fixya does not provide any kind of internet connectivity - methinks thou mayst have directed thy query to the wrong site.
Rokinon D=70mm F=500mm user manual
You can download a manual for almost any equipment by Googling the make and model followed by the word Manual, then follow the appropriate link(s).
Roku2 universal code
From Internet, check it whether it works for you.
52371 and 53061 are the two codes listed for Roku for the RCRN04GR remote. The 53061 code worked with full functionality for my Roku 3.
How do you get out of Roku back to regular tv?
Change the Input on the TV. Like from HDMI 1 to HDMI 2 for example. Or to component video. Trace the wire from your cable /satellite receiver and see where it's plugged into the TV then select that input.
Why doesn't my rokinon 500mm lens work with my Nikn D3100 camera?
The lens does not have the electronics to communicate with the camera. It will work fine in Manual exposure mode. Turn the mode dial to M. You'll have to set the shutter speed yourself, without any help from the camera's exposure meter. You'll also have to focus yourself, of course.
Setting nikon d90
Turn the mode dial to "M". You control the shutter speed by turning the command dial, and you control the aperture by turning the aperture ring on the lens. The camera's exposure meter is shut off and won't help with the exposure. You can shoot a picture and look at it on the display to judge the exposure.
Error messages nikon d7000
Nikon makes several different 85mm f/1.4 lenses, but it appears you're using one with an aperture ring. Turn the aperture ring to its smallest setting (largest f/number). You can control the aperture from the camera body, the same was as on a lens without an aperture ring.
