20 Most Recent
Faema Smart A2 Automatic Espresso Machine - Espresso Machines Faema Questions & Answers
Repair heating element feama e97
Are you installing a new element or do you need to get a new one make sure you get an element gasket as well. Element is on right side of machine. Drain water 14mm plug under boiler. There are 4 wires on element two labeled 3, and one labeled 1, the other labeled 2. Element has 4 coils in two loops, top loop and bottom loop. 1 on top loop 2 on bottom loop the 3's on the other side.
Our coffee machine is continually beeping and the water flow will not flow automatically, is there a reset button or something
It's beeping because it's in programming mode. Usual reason with a machine of this age is that the touchpad has failed. Water gets into the touchpad membrane after a while, which makes the controller think a button has been pressed. If it thinks the STOP button is being pressed/held for more than 5 seconds, it goes into programming....
To confirm: Remove drip tray, take lid off controller box and unplug one of the flat plugs from the keypad (there will be two long thin plugs next to each other, and probably a space or two for extra plugs). When you get the correct one, the beeping will stop and the machine will resume normal operation on the working keypad.
Waterpump makes a lot of noise
It is possible that the water coming into the pump from the mains is obstructed. If you have a water filter, that might need to be replaced. Some of the pumps have a stone filter on them, you will see a huge nut on the inlet side of the pump, that might need to be cleaned. Also check all water lines make sure you have no kinks. Pay attention to the gauge on the machine when the noise is happening if the water dispensing pressure lever should be at about between 3-6 bar when not being used and about 9 when brewing espresso.
How to reset the program of faema x30
Hey, Follow these instructions to reset the program on a Faema X30 coffee maker. Make sure the machine is turned off first. Next, simultaneously push and hold the "Stop" and "Steam" buttons. Press and hold these buttons to start the appliance. Hold the buttons down while waiting for the display to say "Reset." To finalize the reset, let go of the buttons and push the "Stop" button. The computer will restart, and the program's settings will be restored to their original values. Always refer to the user manual for detailed instructions tailored to your particular machine model. Thank You!
Can you help me fix my faema x30 coffee machine not heating one boiler thanks
Hey, Check the power supply and make sure it is connected properly before attempting to fix your Faema X30 coffee maker's non-heating boiler issue. Next, check for any flaws or malfunctions with the thermostat and heating element. If necessary, think about swapping out the defective parts or hiring a pro to fix it.Thanks!
