Question moved from Cars and Trucks.
Stand Mixers don't normally have belts and I don't believe this one does as I can't find spare belts. They are operated by nylon cogs that run in grease. The most likely reason is the she shear pin has sheared. This is a small pin like a nail that goes through a cog or shaft and shears if too much load is put on the mixer beater or dough hook. It often happens if you make bread and have the speed too high.
https://www.google.com/search?q=change+the+belt+in+a+Bodum+electric+mixer
You will need to get a qualified electronics technician to look at it. The issue could be anywhere on the circuit boards inside the mixer. Unless you know what you are doing don't try to repair it yourself as you could make the problem worse.
Spray some WD40 into the eject button. The wait 10 minutes and turn it upside down and spray WD40 down the side of the beaters Leave 10 minutes and try again/ If that doesn't work, you will need full disassembly
