20 Most Recent
Horizon Fitness T82 Treadmill Questions & Answers
My treadmill will light up
If the screen is lit and the screen shows that the belt is moving then it’s the motor controller. If the screen does not show that the belt is moving then it’s the console.
Treadmill displaying temperature over for an mbh
The cause
of this problem is because your powerboad need big power (Amp) to turn the motor (and the belt) This usually happens if your treadmill belt is
not lubricate well or needs change. So,
first try to lubricate your treadmill belt with silicone oil and be sure that treadmill
deck is clean. If the problem continues you must change your treadmill belt.
Greetings
from Greece
Horizon T52 does not work
please see the video and lube too the rollers bearing.
test too the input voltage motor, if there are voltage the motor need repair. see my personal TIPS for motor help, see the b.diagram3) test the output voltage board, for input voltage motor, if there are NOT the board is faulty.Happy New Year. God bless you
