20 Most Recent
Startrac Fitness Products Lamar L1400 Treadmill Questions & Answers
My Lamar L1400 treadmill stopped working. The
Hi, please open the cover where is motor and controller board motor, and see if there are some loose cable. And if NOT tight very well all connector, and wires with a plier.
and turn ON again. If the machine after that present the same problem, you must replac the Controller board motor.
[email protected]
Error code E-2 on Lamar, Ignite 1726 exercise bike
please follow this steps and fix it. God bless you
Check the connections on both ends of the data cable to
ensure they are secure and connected properly. The data cable runs from
the back of the console to the flywheel assembly. The covers over the
flywheel assembly may need to be removed to access the data cable
connection. Verify that there are no bent pins in the cable connection
by detaching the connection and visually verifying all pins are
straight. Reconnect the cable connections, ensuring that the small latch
on the connectors snap into place.
Verify that there are no cuts, crimps or other damage to the
cable. If the cable is damaged, replace the cable with a new, undamaged
cable.
Replace the console if there are no problems with the cable or the connections.
It is saying schedule maintance see owners manual
The manual should point out specifics but this is usually a message that is generated by the miles on the mill. Most important maintenance on a treadmill is keeping belt lubed. We also vac under the hood( motor area) to get out dust, lent and debris. and lube elevation mech. Check owners manual for type of belt lubricant.
Perform Scheduled Maintenance
Contact clubhouse, overiding or attempting to change setting may cause more damage than good. Especially if you don't know what you are doing.
Star Trac 4000 Treadmill Belt and Deck Replacement
How To Replace the Belt and Deck on a
Tools Needed: Phillips Screwdriver, ¼" Allen Wrench, 4MM Allen Wrench, ½" Wrench, Bungee Cord, Pliers (optional). Tools needed may vary depending on your hardware.
- Switch the Power off on the unit.
- Next, unplug the unit from the wall
- Loosen the two lower bolts from the upper portion of the right handlebar and remove them.
- Loosen and remove the bolt in the bottom of the right handlebar.
- Now carefully twist the handlebar clockwise to remove it from the unit.
- Remove the finger guard retaining screws and carefully remove them from the deck at each end of the rear roller.
- Loosen each rear roller bolt by 10 full turns. Then count the remaining turns necessary to remove the rear roller bolts. Remember to write down the number of turns needed to remove the bolts in each side for future reference.
- Carefully remove the rear roller from the unit. Clean any wax or debris buildup from the roller and place it aside.
- Raise the shroud and secure it with a bungee cord.
- Work the drive belt off the motor pulley by hand turning the flywheel while pushing the belt aside.
- Now remove the front roller retaining bolts.
- Carefully remove the front roller from the unit. Clean off any wax or debris buildup and set it aside.
- Loosen and remove the deck bushings from the left side frame rail. Stubborn deck bushings can be removed with the assistance of pliers, once the screws have been loosened completely.
- Move the deck toward the left side of the frame to free the deck from the right side. The deck will move down once the frame has been cleared.
- Remove the deck and belt by raising the right side edge of the deck over the frame rail and sliding it to the right to remove.
- When installing a new belt or deck it is important to note that a new belt and deck surface should always be installed together. Failure to adhere to this guideline will severely shorten the life of the installed parts. Some decks can be used on both sides. However, be sure that each side is only used once. Be sure to install the belt in the proper direction on the unit. Consult the belt manufacturer for proper direction if the belt is not marked or you are unsure.
- Install the belt and deck by first putting the belt on the deck, and then installing them from the right side as a unit.
- Be sure the deck is lined up with the frame and push the deck to the left side.
- Now carefully lower the right side of the deck to insert it into the frame rail and then push the deck to the right as far as possible.
- Install the deck bushings from the left frame rail. (Check with mfr. for proper torque during install process.)
- Carefully place the front roller on the deck under the belt and push it forward into place, while placing the drive belt on the inside of the drive pulley.
- Replace the front roller bolts. (Check with mfr. for proper torque during install process.)
- Now spin the roller by hand while pushing the drive belt onto the pulley. Be sure to spin the roller several times to insure complete installation of the drive belt on the pulley.
- Install the rear roller into unit. Carefully start each bolt and turn one to two threads to ensure no cross-threading has occurred.
- Tighten each rear roller bolt the number of turns you kept earlier for reference.
- Install right handlebar and bolts into the unit. (Check with mfr. for proper torque during install process.)
- Now, Plug in and power on the unit.
- Carefully remove the bungee cord from the shroud and lower it back into place.
- Start the unit at a very slow speed and check for proper belt alignment. Remember to start at the slowest speed possible and be ready to stop the unit quickly if needed.
- If the belt is moving to right side of unit tighten the right roller bolt, If the belt is moving to the left side of the unit tighten the left roller bolt until the belt is tracking properly.
- Caution: make very small adjustments such as ¼ turns and then watch the belt for several moments before making another adjustment.
- Once the belt is tracking properly walk on the unit at a slow speed and check for belt slippage on foot fall. If this is happening tighten each of the rear roller bolts equal turns until the slippage is no longer occurring. Caution: make very small adjustments such as ¼ turns and then watch the belt for several moments before making another adjustment.
- Now use the unit at a jogging speed to check for belt travel or slippage.
- If slippage still occurs make small equal adjustments (1/4 turns) to both sides of rear roller and re-test.
- Install the finger guards once you have enough clearance from the rear roller.
- Some manufacturers require wax or lube during the install process, please consult your owner's or service manual for further information regarding this.
Video on Startrac 4000 Treadmill Belt and Deck Replacement
My horizon treadmill immediately stops after 2 seconds
StarTrac 4500 Treadmill NO RPM Error
Probable Cause
A) Damaged or misaligned RPM sensor
B) Display Cable
C) MCB
D) Filter Network
Corrective Action
A) Check the connection of the RPM sensor to the lower control board. Inspect RPM sensor and disc for build up of dirt, dust, or debris. Clean if necessary. Verify RPM sensor and disc are properly aligned. Units equipped with an "optical" RPM sensor (uses plastic RPM disc) should have the disc evenly spaced between the walls of the RPM sensor. Adjust if necessary. Units equipped with a magnetic "cherry" RPM sensor (uses a metal RPM disc) should have the sensor spaced 1/8" away from the flywheel. Adjust if necessary. B) Inspect the display cable for any nicks or breaks. Replace if necessary. If there is no visible damage to the display cable, wiggle the display cable to verify intermittent connection. If by wiggling the display cable, the PWM LED on the lower control board does not flash or intermittently respond, replace the display cable.
C) Refer to the NO RPM Flowchart from the service manual for MCB testing.
D) Refer to the NO RPM Flowchart from the service manual for testing of Filter Network.
Star Trac 4500 Treadmill NO RPM Error Code
Stairmaster quinton 612 plus error code e201
Quinton Error E201
Probable Cause
Grade Over Limit Fault. Turn jackscrew counter clockwise to get within range.
Corrective Action
- Use Up or Down arrows to bring grade into range.
- If error persists, replace grade actuator or VSD. NOTE: Belt and display may continue to be used during fault conditions by pressing clear.
Quinton Treadmill Error Codes E201
Startrac 4500 hr shuts down
The calibration instructions can be found in the service manual.
http://www.sportsmith.net/images/product_support%5Cstartrac%5CTechnical%20Manuals%5CTreadmills%5CSvcMan%20TR4500.pdf
