20 Most Recent
GMC Yukon XL Road Bike Questions & Answers
How do I rotate the handlebar stem on gmc yukon xl road bike?
If the stem is installed backwards that means it is pointing at you when you are riding? To correct this you will need to remove the handlebars from the stem. This done by removing the two allen bolts front the front of the stem. Now loosen the two(may be only one) allen bolt heads on the side of the stem. Now rotate the stem. Reinstall the handlebars, front mounting plate and bolts (make sure the bolts are tight). Make sure the stem is straight and tighten the allen bolts on the side.
If the stem was installed incorrectly it may be a good idea to have the bike checked over by your local bike shop to insure nothing else is installed/adjusted incorrectly.
Hope this helps. If you need any other help you can contact me at
[email protected] Thank you
I have a brand new yukon xl series bicycle, where do I get info.
Chain noise and gear slippage is most frequently due to binding links. Flip the bike upside down, prepare to get your hands dirty, and then flex each link connection. When you find an uncooperative link, spray it with something like WD-40 and work it until it moves freely. Alternatively, view the chain while pedaling by hand when it is upside down, and look for any areas that may be rubbing.
When shifting gears the chain starts to hop.
It is likely that your chain, coggs, (rear gears), and front sprockets are all wearing out. The gears wearing out now are likely the ones that are used the most. You will probably have to replace the chain, coggs,(freewheel), and maybe the front sprocket that is used the most refer to Parktool.com
Install spear pump
Sounds like the braze ons, that's what they're called, are broken in the frame. Only thing left is to drill them out and replace them with Rivnuts. Your local bike shop should be able to handle that.
4/7/2014 12:38:47 AM •
GMC Cycling
Answered
on Apr 07, 2014
Tomahawk E Series Exercise bike loud peddling sound
Standard WD40 is just a 'quick fix' as it isn't an actual oil unless the can is clearly labelled as "Bike All Condition Lubricant". It'll be best to buy a proper light oil like 3in1, 151 Super oil or an actual chain lube.
This 'clickey' noise. Is it random and happening every so often or is it a constant, regular click that changes with the speed your pedalling at? Check for slack in the chain. as you wiggle the chain up and down there should only be about a centimetre of movement in the chain. If it's too slack or too tight it can make strange noises. Check the axle bolts and nuts to make sure they're not loose. Check the wheel is mounted straight. If it's turned left or right the chain will 'skip' as it's slightly missing the cog teeth on the wheel. Use the frame at the rear end of the wheel as reference and measure how far the side of the wheel is from the frame on both sides. It should be about the same both sides.
9/22/2023 12:16:04 PM •
Cycling
Answered
on Sep 22, 2023
New Balance 6100 Recumbent Bike making a clanking noise when pedaling
I have done a tremendous amount of research on this problem. New Balance (Fitness Quest) is out of business as of late 2012 and no parts are available. The main bearing or crank bearing set is 100% compatible with Proform part number 295560. Since New Balance put their name on this product, they have stated they will reimburse customers for the repairs.
4/5/2023 11:21:09 AM •
Cycling
Answered
on Apr 05, 2023
A manual for a manual for a Genesis model gs52686 men's bike a V2 100
Il est possible de trouver un manuel pour le v?lo Genesis GS52686 V2 100 en visitant le site web du fabricant ou en contactant directement le fabricant pour demander un manuel. Il est ?galement possible de trouver des informations sur ce v?lo sur des forums de discussion ou des sites web sp?cialis?s dans les v?los. Il est recommand? de v?rifier si le manuel est disponible en ligne ou de demander une copie imprim?e aupr?s du fabricant. Il est important de noter que les r?glages de la fourche de suspension et de la suspension arri?re peuvent varier en fonction du poids, de l'exp?rience et des pr?f?rences de conduite de chaque cycliste. Il est recommand? de consulter un m?canicien ou un expert en v?los pour obtenir des conseils sur les r?glages appropri?s pour votre v?lo.
3/14/2023 6:23:13 AM •
Cycling
Answered
on Mar 14, 2023
