20 Most Recent Canon PowerShot SX40 HS 12.1-Megapixel Digital Camera Questions & Answers
0answers
Lens error
Be the first to answer 4/19/2014 2:38:20 PM • Canon PowerShot... • Posted on Apr 19, 2014Be the first to answer
My Canon pc1234 keeps saying I have a memory card error. How come?
The card may be corrupted and unusable. Try with a new SD Card. If that doesn't work, you need Canon Service. Try formatting it in the computer, add images and see if you can see the images in the camera.
10/1/2021 8:49:37 PM • Canon PowerShot... • Answered on Oct 01, 2021
My Canon A250 batteries are getting drained when i switch on
If the batteries are the same age as the camera, they are probably worn out. Try replacing them.
1/8/2018 4:17:55 PM • Canon PowerShot... • Answered on Jan 08, 2018
Memory card error Canon ELPH530HS
What did the error prompts?
12/22/2017 3:38:57 AM • Canon PowerShot... • Answered on Dec 22, 2017
Orange light flash sd550 750
Settings menu to off the option
11/17/2017 10:50:54 PM • Canon PowerShot... • Answered on Nov 17, 2017
2answers
How do I retrieve pictures after they have gone missing from my card?
So the pics vanished from the memory card, right? Perhaps you can insert the card to your computer and try a photo recovery tool on it. Give this app a try if you're a Mac user. Recover Digital Photo Music and Video on Mac OS
8/17/2017 8:45:03 AM • Canon PowerShot... • Answered on Aug 17, 2017
I have Canon PowerShot A3300 IS won't play back pictures.
Try doing a factory reset.
7/3/2017 8:10:24 PM • Canon PowerShot... • Answered on Jul 03, 2017
How do I attach the wrist strap to the Canon PowerShot D30 camera
The wrist strap has a thin loop on one end. Thread this thin section (like threading a needle) through the strap hole. (It's on the left side of the camera. There are two openings with a bar over the top of the center of them at the bottom corner of the camera body.) Start threading from the middle of the body of the camera and push the strap towards the bottom of the unit. You may need to twist the loop to narrow it and keep it tight. Once you have this narrow loop through the camera, open up the loop and slide the thick material through the center of this thin loop. Pull the wrist strap until the thin loop tightens around the bar. This is shown on page 12 of the D30 manual. The manual is available from Canon support on the Powershot page: http://gdlp01.c-wss.com/gds/5/0300013985/02/psd30-cu2-en.pdf. The direct link to the manual is http://gdlp01.c-wss.com/gds/5/0300013985/02/psd30-cu2-en.pdf . I hope this helps. Cindy Wells (Many lanyard straps for electronic gear work the same way. Threading the narrow section under that bar does require decent near point vision. People who are far-sighted may need to wear bifocals or ask someone younger to assist.)
2/18/2017 10:49:34 PM • Canon PowerShot... • Answered on Feb 18, 2017
How do I to decrease file size to a maximum 10mg? I have SX210 Power Shot
Reduce the quality in the menu
2/2/2017 11:23:21 PM • Canon PowerShot... • Answered on Feb 02, 2017
3answers
The solution disk for my sd870is is now outdated, so I cannot download my pictures anymore. what to do?
Get a card reader for your computer, if it doesn't already have one. The card will then appear as another hard drive, and you can transfer photos the same way you transfer any other kind of files. Using a card reader is also likely to be faster than connecting the camera to the computer/
1/4/2017 10:57:34 AM • Canon PowerShot... • Answered on Jan 04, 2017
Powershot 5753 jams after each attempt
Each attempt to do what ?
12/28/2016 5:49:06 PM • Canon PowerShot... • Answered on Dec 28, 2016
LOST THE VOLUME ON VIDEO, HOW TO FIX?
Do you mean when playing video back on the camera? If so, when the video is playing, press on the top of the wheel, the part with the triangle pointing upwards (up-arrow). You should see the small volume level indicator get an increasing number of bars and the volume will increase.
12/12/2016 4:11:13 PM • Canon PowerShot... • Answered on Dec 12, 2016
3answers
My Canon PowerShot A 1100IS will not turn on
Hi Charlie, Please provide additional info if you really want help in this site. Questions with sufficient information do get answered sooner than others so consider that. Otherwise, check answers to previous questions of similar nature and you might locate a suitable solution for your question.
10/30/2016 10:43:46 PM • Canon PowerShot... • Answered on Oct 30, 2016
Canon PowerShot SX40 HS 12.1-Megapixel Digital Camera Logo
1 questions posted
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
PowerShot Canon
  • PowerShot Canon
Most Popular Question
older canon power shot sx100 when
  • Cameras
