20 Most Recent
Nikon Coolpix S800c - Digital camera - compact - 16.0 Mpix - 10 x o Questions & Answers
How do you hard reset a nikon coolpix s800c?
There is no such thing as a reset button on your camera. If something oes wrong, or the camera acts strange, the only thing you can do is switch it of and after a few seconds switch it on again. This should be equal to a cold boot from a computer. This should solve all software releated problems. Sometimes yuo could go deeper, by also removing the battery and the memory card. and replacing them after a few moments. But if the problem keeps coming back, it will not be a software problem. Then you could look a bit deeper, like if the lens barrel is blocked, or contacts from battery and or memory card are dirty ot bent. If you can't find a thing, please contact a Nikon Certified service centre.
Change to resolution after picture taken
Sorry, can't be done. Those pixels weren't recorded, so there's no way to regenerate them.Think of it this way. Suppose you look out the window and see a red car drive by. Look out the window an hour later and maybe a blue car drives by. Now, how many white cars drove by between those two cars? If you weren't looking (or had a surveillance camera), there's no way to tell. In your picture you've got a red pixel over here and a blue pixel over there. There's no way to tell what was in between.There are some tricks that can be done to interpolate. If you have a bright red pixel and next to it a dark red pixel, then the pixel between them probably was a medium red. But maybe not: there could have been a blue object in between. Or the pixel in the middle might have been the same color as one of its neighbors. There's just no way to be certain.
Just bought Nikon p600 and cant connect to WiFi help
U need to download nikon wmu software from google playstore or appstore. Then start wifi of ur camera and then start wifi connection in ur mobile.select "nikon p600" in wifi setup.when connected, start application named "wmu" in ur mobile.wait for the connection.after few seconds wifi connection will be established.hope this would help u!
My Nikon b500 Coolpix won't turn on just flashes green
It flashes green when it is basically on but in a sub mode that I'll call CHARGE MODE. If it is flashing that means the battery is charging. I suggest to let it continue to charge until it stops flashing and then remove the charger connection. When the camera is sitting all by itself with nothing connected you can then turn it on.
The screen on my Coolpix 500 looks like a chemical was poured on it. It is not scratched, what can I do
Is it the screen, or the screen protector ? If the latter, just remove it and replace it. If it is the actual screen, first of all try a lint-free cloth barely dampened with distilled water, and test it on a corner, see if that works. On no account get the camera wet. If that is unsuccessful, try adding a very little diluted washing-up liquid, and try again. Should that not succeed, I would advise taking the camera to your local repair facility for their expert advice.
