20 Most Recent Electrolux 18 in. ESL4114 Slim-Line Built-in Dishwasher Questions & Answers
18answers
Dishwasher Dishlex DX302WB No Hot Water
Thank you This worked for me!
The heater was ok found dry joint on pc board
see attatched photo
Took top 6 screws out of door holding front panel in place
Removed front switch panel
I then labeled the 6 cables with 6 being for the heater
Removed pc board from housing to find dry joint
using small piece of wire and solder repaired board
re assembled
now as good as new
11/15/2022 8:42:58 PM • Electrolux 18... • Answered on Nov 15, 2022
0answers
What can I do to make it work?
I would have advised you before placing the tablet dry compartment with a dry cloths otherwise tablet would be stuck together. If does't help then put the tablet directly into the sink and never choose a quick program if you do not have functions (like 3 in 1, multi tab and so on....) that extend the time of duration of washing phase and give enough time for dissolve tab. Sometimes people on the upper basket hang up various odors or put dishes that may prevent to open small door to the end and dropping tablet. The tablet most likely will drop during the washing cycle but the remaining time is not enough to dissolve the tablet and wash result will be bad. Dado
1/3/2015 9:10:22 AM • Electrolux 18... • Answered on Jan 03, 2015
Why dishwasher not heating water
I have same brand dishwasher as you but different model, suggest it would still have the same fault as mine. I searched for the faulty solder join on my circuit board as per the forum and soldered the area but still would not heat. I spoke to local parts supplier who stated that heater element is not the problem, it would definitely be the circuit board. I took the circuit board to them and paid for a changeover board (approx $90 AUSTRALIAN). I went home and installed the circuit board in the dishwasher door and started it up. It does not show start up settings on display as per normal but just start the dishwasher anyway and it resets the circuit board after running a complete wash cycle (any cycle will do, doesn't matter which one you choose). All worked well after that, no problems since replacement of board.
10/16/2014 11:13:41 PM • Electrolux 18... • Answered on Oct 16, 2014
Dishwasher trips mains
Good Morning Friend, I understand that your Electrolux dishwasher, model# ESL4114, keeps tripping your main breaker. This appears to be a UK Electrolux dishwasher. I suggest contacting the manufacturer directly for further assistance. Hope this is helpful. -Best Regards- WP
5/21/2014 12:21:26 PM • Electrolux 18... • Answered on May 21, 2014
Dishlex 302 leaks from underneath
Good Morning Friend, This appears to be a UK Electrolux dishwasher; however, if you have a US Electrolux model, here are a few tips you can attempt to troubleshoot the issue: First, Use only fresh detergent designed for automatic dishwashers. Measure detergent carefully. Possibly try a different brand of detergent. Secondly, spilled rinse aid can cause foam and lead to overflowing. Wipe up any spills with a damp cloth. Lastly, check to see if your dishwasher is level. If your dishwasher is still leaking, after trying the above solutions, I suggest contacting the manufacturer for further assistance. Hope this is helpful. -Best regards- WP
5/21/2014 12:07:33 PM • Electrolux 18... • Answered on May 21, 2014
W/H Dishwasher 915 Model had no hot water,resold dry joint according to the instruction as following, but only working one wash, same problem happen again. need help.
If soldering the relay worked once then I would recheck the joint and solder a solid wire between the leg of the relay and the terminal and bypass the track
4/1/2014 10:12:12 AM • Electrolux 18... • Answered on Apr 01, 2014
0answers
3answers
Filling the rinse aid compartment
Download your free instuctions manual here
http://www.devicemanuals.com/userguidesearcher.php?search=sl
9/2/2013 9:25:55 PM • Electrolux 18... • Answered on Sep 02, 2013
Dishlex global 500 dishwasher - light inside on but no lights on control panel
Hello misi340 - Try reprogramming the dishwasher by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it was unsuccessful, then the unit could possibly be experiencing a communication error with the control board or wiring failure which only a professional can help with.
2/15/2013 7:26:51 PM • Electrolux 18... • Answered on Feb 15, 2013
0answers
The machine trips the circuit board after 20 minutes, this happens each time ou switch on.
Hello Robert Mansfield - Is the dishwasher hook to the same line as the garbage disposal? If so, it could be pulling too much power or not the right voltage outlet. Other possibly could be a communication problem with the control panel. I would strongly suggest contacting a professional to move forward accurately.
10/11/2012 2:17:46 PM • Electrolux 18... • Answered on Oct 11, 2012
Electrolux 18 in. ESL4114 Slim-Line Built-in Dishwasher Logo
Popular Tags
99 questions posted
Top Electrolux Dishwashers Experts
Mike Cairns
Mike Cairns
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Electrolux Dishwashers
Most Popular Question
dishwasher dishlex dx302wb no hot water
  • Dishwashers
