20 Most Recent
Vizio E390-A1 39" 1080p 60Hz LED 2.95" ultra-slim HDTV Questions & Answers
TV cannot turn on
Check and replace the damaged component/s at its main board. Contact any service technician.
Audio volume fluctuates randomly
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Why is my vizio 39 inch e390-a1 will not turn back on
Check and replace it power supply regulator board. Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" or "
Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
Do a search by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
E390-a1 sound from speakers not working
Tries tv unplug replug it back like about an hour later for the tv do a resetting itself back to the factory setting,this might help to solved this problems.Check the sound setting in the tv setup Menu it to speaker out not something else.If u are using the tv speakers.If u are using sound bar system or reciever system make sure all the connections output are correct and functioning,this will solved the problems.
