20 Most Recent
RTO Tectrix Personal Stair Climber Questions & Answers
Tectrix personal climber - the resistance is very tight
There are a few ways that you can try to adjust the resistance on your Tectrix personal climber. First, you can try going into test mode and using the up and down arrow keys to adjust the resistance. If that doesn't work, you can try resetting the machine back to its original factory settings. To do this, you'll need to access the menu system on the machine and navigate to the reset option. Finally, if neither of those methods work, it's possible that the previous owner of the machine adjusted the settings for their own body weight. In this case, you'll need to contact Tectrix customer service for assistance in resetting the machine. Thanks for your question!
My Tectrix Stairmaster Personal Climber is
I would take the cover off and inspect the drive chain to see how much play you have and also check the sprocket to see excessive wear. You can call Cybex International @ 1-800-677-6544 to order parts you will need the serial number that is located in front of the pedals their is a sticker with the serial number on it!
