20 Most Recent Epic View 550 Treadmill Questions & Answers
If you lift your treadmill deck up, you will find 2 screws underneath, on the side, towards the front. remove them and that should do the trick.
Epic View 550... | Answered on Jan 20, 2018
It is most important that when assembling your system, all parts attached with screws, nuts, and bolts are fully tightened. That is true especially with the hand rails that are affixed to the Front of the platform to the rear. Recheck the motor mount and make certain it is solid. Every unit when assembled should be identical, however, if a part is not true (meaning it is bent, dented, etc.) it may not align 100% and make a noise when the device in in operation.
Epic View 550... | Answered on Jan 13, 2018
Heidi, There will be quite a bit of disassembly required to remove belt, I have attached your manual, which shows an exploded view showing what has to be removed to access rollers and remove belt. you may get away with dissembling/remove front motor cover,remove rear roller and front roller.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://pdfstream.manualsonline.com/d/de84f386-3308-4d84-a2ed-a52898e55aa5.pdf
Treadmill Walking Belt Installation Video by Treadmill Doctor
How To Remove Replace Treadmill Belt and Deck Green Fitness Company
Epic View 550... | Answered on Jul 24, 2016
If you wish to get some derails about treadmill repair then check the below added link
http://electro-medical.blogspot.com/
Epic View 550... | Answered on Jul 07, 2016
epic view 550 treadmill video 2 - YouTube
? 2:08
https://www.youtube.com/watch?v=fSIuoh_bZN4
Mar 9, 2010 - Uploaded by Epictreadmillowner
epic view 550 treadmill video 2 ... ICON Canada doesn't really support this and the independant technicians ...Epictreadmillowner 1,181 views.
Epic View 550 Treadmill Review - YouTube
? 3:02
https://www.youtube.com/watch?v=kNiFOcrV9r4
Nov 29, 2012 - Uploaded by Treadmill Review Guru
... .com/epic-treadmill-reviews/epic-view-550-treadmill-reviews-ratings/ ... Nordic track has the track and google maps by i-fit you can download and run anywhere ... The review says it doesn'thave the track/lap but it does.
Epic View 550 Treadmill video 3 - YouTube
? 1:59
https://www.youtube.com/watch?v=YjqgZS-1qlw
Mar 11, 2010 - Uploaded by Epictreadmillowner
Epic View 550 Treadmill video 3. Epictreadmillowner ... I have had 3 different console units, and now the tv doesn't work either!
Epic View 550 Reviews - MyTreadmillReview.com
mytreadmillreview.com/epic-view-550-reviews-2
Just got off the phone with Icon. Here's the Fix: 1) With the remote control that came with the Treadmill press "Menu". 2) Then enter "1591" quickly with the number buttons. 3) Use CH or CH - to choose flip orientation. 4) Press VOL or VOL - to select 5) Press Exit
That should do the trick!
Epic View 550... | Answered on Mar 25, 2016
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Epic View 550... | Answered on Mar 01, 2016
You have to lift up the back of the treadmill a little to access 2 phillips head screws that keep the motor cover on, (note that you will also have to unscrew a few phillips head screws on the bottom front of the cover as well in order to remove it completely). Before you begin lifting the back of the treadmill platform off the ground to access the screws underneath make sure the treadmill is on a zero incline setting and it helps to find a sturdy object you can rest the tail end off the treadmill on about 1 to 2 feet above the ground giving you enough room to access the screws underneath. Another option is to lift the treadmill platform all the way up and lock it in an upright position using the locking mechanism and lock handle that is located underneath the machine. I find this route to be unnecessary and cumbersome for what you want to do. Once you lift the treadmill up you will see the 2 small Phillips head screws near the front of the treadmill running platform that you need to unscrew in order to take off the motor cover. You also need to unscrew a couple small screws under the machine located on each side of the wood running board. These screw fasten the top inner plastic side covers onto the top of the running platform which needs to be taken off in order to access the back rollers. Make sure you collect the screws in a way that you will remember where they go later when you reassemble as this is your first time taking them out and you might forget later. Now with the bottom screws out, lower the back of the treadmill down level on the ground and pull off the motor cover, and the Left and Right INNER plastic running platform covers. With the inner covers removed you will find yet another small set of screws fasting the main plastic side covers to the running board which require an allen wrench to unscrew. Use the small wrench that came with the machine if you have it handy. With those off you can pull the main Left and Right plastic running board covers off, just make sure to carefully unsnap them from their snap points near the bottom rear of the machine. With all the covers removed you can now access the bolts that hold your treadmill rollers in place and the drive belt which you will have to slip on and off the motors drive pulley and the front roller using a pull and turn technique. The back rollers are simple and can be removed by unscrewing the tension bolts at the back of the treadmill and pulling the roller through and out of the belt. With drive belt set aside and all roller bolts removed you can take out the front roller in the same way you removed the back roller. Replace the treadmill belt and reassemble the machines components in the reverse fashion you disassembled them using these instructions. Doing this yourself will save you hundreds of dollars service man visits in the future.
Epic View 550... | Answered on Jul 18, 2014
Epic View 550 Treadmill Logo
170 questions posted
Top Epic Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Colin Stickland
Colin Stickland
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Epic Exercise & Fitness
Most Popular Question
change walking belt epic view 550
  • Exercise & Fitness
