20 Most Recent
Proform 575 Crosstrainer Treadmill Questions & Answers
My son was running on the treadmill and a fire
the motor or controller has burnt up do the following to test the motor;
# get a 12-18 volt dc battery fully charged(like one from a cordless drill)
# Make sure it is fully charged, because it won't work if not
# attach the + and - to the motor red is + and black is -
# If the motor turns slightly your motor is ok, if not the motor is bad and would need replaced
# if the motor is ok then your motor controller(the board with the metal) is malfunctioning and would need replaced.
Need manual
Hi ,check the link bellow for the user manual of Proform 575 Crosstrainer User manual
My proform 575 treadmil keeps
Hi michelleboon,
Your treadmill is likely overcoming the home's ability to provide the power required that's why it keeps tripping. Most new treadmills require a dedicated 20 amp line. As the treadmill breaks in, it will draw less amperage but the long and the short of it is to check the owner's manual for the power requirements and then check the breaker that it's on. You can try to elevate the treadmill somewhat as this changes the user's gait and the result is a lower amp draw. Also, make sure to provide the treadmill with the power required.
If after checking what I mentioned above and still the issue persists it could be the motor that has problem or the drive system that the motor drives. If something is bound up, the motor could draw much more current than normal. You will need a local repairman to do further checking and repair with this.
Hope it helps.
Thank you for using Fixya.
Recently purchased the Crosswalk 570. Assembled
recently purchased a crosswalk 570 treadmill and used it and it worked fine but when we tried to use it today the machine made a strange noise under the hood. we noticed that the belt on the track was slightly rubbing against the hood. How can we fix it?
As soon as weight is
you have adjust nuts on end ..u might have to take off the covers ..do them up equally ..job done i hope :)
