20 Most Recent Epic 450 Mx Treadmill Questions & Answers
An overload causes the breaker to open. First: The motor might have a bad field winding or internal partial short: Second: A bearing on one of the rollers may be shot? You can check for this by simply walking on the tread. It should move, if not there is a bad bearing. A far out reason is that the breaker is opening at less than rated current. (failed breaker). If you have a long heavy duty extension #16 gauge wire (18 gauge minimum), try another outlet that you know is on another breaker.
Epic 450 Mx... | Answered on Feb 02, 2015
1.6km =1,600meters.
Epic 450 Mx... | Answered on Aug 01, 2012
1) Adjust the REED switch,clean, and tigh the connector wires.see the diagram attached.
2) See inside for any fuse blown adn replace, or c.breaker reset
3) Reset the machine. Tight any connector, and wires looses, or breaker use the DVOM , see the diagram
God bless you
Epic 450 Mx... | Answered on May 09, 2012
Dear Sir:
As you must understand the treadmill use the most advance electronic design.
Please do the following:
1)use contact cleaner(radio schack or whatever)
2)Inspect the fuse.
3)Tight the ribbon cable INSIDE from the keypanel(not the console)
4)Tight the connector from the console going to the main board motor.
check this block diagram for to see if anything can help you in the treadmill. If you do not resolve your problem. can be board console vs . main board motor.
2_14_2012_7_36_06_pm.gifGod bless you. sincerely.
ernesto a cuadra
managua, nicaragua
Epic 450 Mx... | Answered on Feb 14, 2012
sincerely.
Merry Christmas.
ernesto cuadra
managua, nicaragua2q==
Epic 450 Mx... | Answered on Dec 24, 2011
Hi drnelson3,
This problem is as a result of a bad control panel. The control panel controls all the functions of the unit it accepts commands and executes them. Often times it would accept a command but not execute as a result of malfunctions on the control board. This is why a times it comes on and doesn't function. The control board is not totally bad but suffers from partial failure therefore the problems.
Best solution is to get the control board replaced this can be done by any service repair personnel or simply contact the nearest dealer for a repair person.
Hope it helps.
Thank you for using FixYa.
Epic 450 Mx... | Answered on Aug 29, 2011
You must see with a volt meter, if you are getting arequired power. It can be weak motor or defective motor controller issue. The interiormotor links are loose or the belt is dried up use some basic lubing by grease.If the problem still exists then you may need to replace motor controller ormotor.
Epic 450 Mx... | Answered on May 10, 2011
sounds like the belt needs lubricating or perhaps the moving parts inside.
Epic 450 Mx... | Answered on Apr 09, 2011
the console's keypad overlay is bad and the console will need replaced
Epic 450 Mx... | Answered on Aug 13, 2010
you will need to test the red wire coming to the console with a volt meter to see if you are getting the required 9-12 vdc if you are replace the console, if not replace the controller. Now if just the buttons are not working replace the console. You can get a console from iconservice.com
Epic 450 Mx Treadmill Logo
23 questions posted
Top Epic Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Colin Stickland
Colin Stickland
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Epic Exercise & Fitness
Most Popular Question
epic 450 mx cannot adjust speed programs
  • Exercise & Fitness
