20 Most Recent
Cardiozone 5 Hp 325 Lb Limit Breeze Elite Treadmill Questions & Answers
I need to move the
the console first and then the uprites that hold the console. that should be enough
I have a Proform 860, I moved it to another room
Hello. Check these items:
1. The outlet - plug something else into that same outlet to be sure you don't have a blown fuse or a kicked circuit breaker.
2. The treadmill key. Remember that your treadmill will not turn on with out the little magnetic key in place.
3. The switch on the treadmill near where the power cord goes into the machine.
Hopefully one of these will solve your problem. Regards, Joe
PS Kindly rate my answer as helpful. Thank you.
Cardiozone Elite Plus HR T treadmill and am getting an error E11
Hello again
Having typed everything below the dotted lines for the last 30 minutes, I found this. It has a magnetic speed sensor on the pulley
https://www.justanswer.com/fitness-equipment/2srkz-just-moved-cardiozone-elite-max-hr-treadmill.html
Here is the parts diagram and it shows no speed sensor and all parts are unavailable.
https://www.fitnessrepairparts.com/equipment/Select/7631/CardioZone/CZE-Elite-Plus-HRT
Parts Diagram closeup
https://www.fitnessrepairparts.com/equipment/7631/diagrams/7403
That is contradicted here, but my view is that they are guessing because the parts diagram shows no sensor and if it was there and a part of the management system and expected to fail, it would be. There is a picture of of two sensors from Amazon and eBay, one is a Hall Effect Sensor, and the other is a Magnetic sensor. If it has them, you wouldn't be able to miss them and they would be connected to Part 17 - Controller.
https://www.google.com/search?q=cardiozone+elite+plus+hr+t+treadmill+sensor+replacement
Generic Treadmill Sensors
Treadmill RPM Speed Sensor - Replacement for Pacemaster Bronze, Pro, Plus, Plus 2, Elite, & Select Treadmill
$21.14
Amazon CA
High Quality Treadmill Magnetic Sensor Speed Sensor For Running
$12.89
eBay
Free shipping
Speed increases dramatically when trying to increase slowly on CardioZone Fast Track Elite II
This could be cused by the the display cover you touch to control the functions pressing on the touch switch array just under it. Carefully remove this. it is held on by adhesive and see if the symptom goes away. If it does, look for any dents on the cover. I have worked with these type of switches for nearly 20 years and they can be problematic. The other possibility is the mechanical switches you use to increase/decrease speed or tilt. They plug in seperately and you can disconnect them to see if they are causing the problem.
12/29/2013 11:28:11 PM •
Cardiozone...
Answered
on Dec 29, 2013
I have two cardio zone
Dear Sir:
I will help you.
Please in all this check in, use The Vom digital:
1. NoPower
o 1
Make sure that the surge protector being used isproperly grounded and turned on. Check that the treadmill power cord isproperly plugged into the surge protector.
o 2
Check to see that the key is inserted in theconsole.
o 3
Check the circuit breaker on the frame near thepower cord. If the reset/off circuit breaker has tripped, wait 5 minutes andthen reset the breaker by pressing the switch in.
4)Check the circuit breaker from the main panel( wall) and Measure the Voltage for properly 115VAC. if there .
Hoping help you, contac me if there are something extra.
blessing.
E.CUADRA
Managua, Nicaragua.C.A.
My treadmill belt just stopped, message error E
Unplug your unit, then remove motor shroud have a good light the sensor is either mounted on the frame by the front roller/pulley unit or it is mount on the motor sometimes by the flywheel sometimes on the opposite end. Next step is to locate the motor control board and plug you uit in. Your board should ligt up with red ,green, or amber L E Ds now manually move the running belt and you should see one of those lights flicker or not if it does then the sensor is working , then we other issues, if not either we have a defective or misalign sensor. An if your unit needs lubrication use a synthetic silcone product.
