20 Most Recent Cardiozone Supersport Hr Club Commercial Treadmill Questions & Answers
1st take side rails off front hood .you have afront roller and a back roller. for the front take out the two or one bolts holding the the roller in placenow the back roller take out the bolts that hold the roller in place . now on the deck there is 3or 4 screwson each side holding the deck in place. slide w/ belt off put on new deck.install screws, rollers ,bolts.. now center w/belt and adjust tention on w/belt
Cardiozone... | Answered on Aug 05, 2015
Your problem might be that a magnet has fallen off. Here's an illustrated guide which should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Cardiozone... | Answered on Apr 21, 2014
Your controller is shot. Replace your controller
Cardiozone... | Answered on Jan 04, 2014
This usually means a faulty LCB or motor.The fact it has not been used much doesn't matter. It is 7 years old. Usually you can not see faulty parts on the LCB. I do think if you really want the answer call a treadmill repairer . If you don't know what you are doing it can be dangerous.
Cardiozone... | Answered on Dec 04, 2013
replace the old batteries and clean the contacts with c. cleaner
2) tight and clean the ribbon cables insides.
3) tight the upper and lower connection , and clean
4) Adjust the Reed SWITCH, see the diagram attached.
Cardiozone... | Answered on Oct 10, 2013
see the video and proceed according. God bless you
2) LUBE the rollers bearings too
3) test the drive belt motor, and replace it
4) Test the input voltage motor, if there are the motor need repair, see my personal TIPS for help
5) Test the output voltage board, for input voltage motor, if there are NOT THE board is faulty. see the block d.
God bless you
Cardiozone... | Answered on Nov 30, 2012
Lets eliminate the motor first, unplug unit remove motor shroud fin the 2 leads from motor to lower board. Connect a 18v DC battery to the leads this start the motor to move at approx. 1 mph if it does motor is good,if not you may worn motor brushes worst case open connection in the motor.
Now if the motor is good then reconnection the leads and plug in unit the lower board should have some LEDs lit up. Now find the LED that says PWM start unit if that light should start to flicker then the upper board and wire harness are work properly. Turn off the treadmill then turn it on and with a multi meter insert the leads into the connectors that go to the motor, then put the meter on 200v DC then start the treadmill you should get a reading 5 to 10v DC if you get 0v DC then the board will need replacing
Cardiozone... | Answered on May 28, 2012
Dear Sir:
The best way is to go to the company, and they can resolve your problem.
Otherwise you will be lose your time. Remember the factory has many options with the manufacturer of the screen, and gave the o.k for your equipment.
sincerely
Cardiozone... | Answered on Dec 03, 2011
Watch the videos:
http://www.youtube.com/watch?v=TquYcOzGIw4&feature=related
http://www.youtube.com/watch?v=9G4MZh8JO2Q
http://www.youtube.com/watch?v=M7qJrRbdfBc
http://www.youtube.com/watch?v=MIIxoPtvhy8hthttp://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnesshttp://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
Some equipment has board for relais. Test if the relais for Down and Up and closing and open. and cleand contact with special spray contact cleaner (radio schack or computer store). Finally see some loose connections or wires.
12_3_2011_5_05_19_pm.gifSEE the block diagram, and now you will have strong resultant for to determine what is faulty. Look how the main motor has the90% aprox functions in any treadmills. sincerely.
Good luck.
E.CUADRA
MANAGUA, NICARAGUA. CA.
If the console takesbatteries, replace them. If this does not work or your console does not requirebatteries, check the reed switch or optic sensor. Reed Switch:Unplug the treadmill and remove the motor hood cover. The reed switch is mountedon the frame next to the front roller pulley. There is a magnet glued into thefront roller pulley. When adjusting the reed switch, make sure it is pointingdirectly at the magnet. Move the tip of the reed switch within 1/8" of themagnet. Also, check to see that the wire is not damaged, and is connected tothe console. 12_3_2011_4_59_31_pm.gif2nd Step: tight the keypanel vs Display board and clean with contact cleaner spray . Tight the connector from Display Board vs Main Motor Board.
See the block diagram how the main motor board has aprox 90% functions in any treadmill. Good luck, Now you will strong resultant in determine what is faulty.
Cardiozone Supersport Hr Club Commercial Treadmill Logo
33 questions posted
Top Cardiozone Exercise & Fitness Experts
Jesse Garza
Treadmill Repairs...
Are you a Cardiozone Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Cardiozone Exercise & Fitness
Most Popular Question
e1 error cardio zone supersport
  • Exercise & Fitness
