20 Most Recent Life Fitness T3 Treadmill with Advanced Console Questions & Answers
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Life Fitness T3... | Answered on Nov 15, 2018
LED Blink Patterns on the Control Board Treadmill
Blessing
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Life Fitness T3... | Answered on Dec 18, 2017
This is most likely caused by a worn treadbelt. Try lubing the belt Have unit looked at by a qualified tech #wilitalube
Treadmill Repair 877 805 1030 Wilita 100 silicone treadmill belt lubricant...
Life Fitness T3... | Answered on Mar 07, 2017
Assuming that the console stays on, it seem you have one of three problems
  1. Your front roller is faulty
  2. Your Treadbelt is loose
  3. Your drive belt is loose
You may also have a combination of two or more of the above issues.
Exercise equipment service Treadmills Ellipticals and Bikes Parts Assembly...
Life Fitness T3... | Answered on Jan 23, 2016
Precor Error 29, Excessive AC Input Current Probable Cause 1. The running belt and/or deck are badly worn.
2. Bad lower PCA.
3. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
  1. Check the amp draw using a clamp on AC volt-amp meter during loaded and no load conditions and compare values to a similar treadmill that is known to have a good running belt and deck. Replace the belt and/or deck if necessary. Don't forget, some units have a double sided deck which means it may be flipped over rather than replaced if it has an unused side.
  2. Test unit with a known good lower PCA. Replace lower PCA if necessary.
  3. Test unit with a known good drive motor. Replace drive motor if necessary
Precor Error Code 29
Life Fitness T3... | Answered on Oct 23, 2014
error 3 means the waking belt starts moving without any command. Make sure that you are not moving the belt manually before the treadmill stars .
for more details check the link
electronics repair help LIFE FITNESS T3 T3i T5 T5i T7i TREADMILL ERROR...
Life Fitness T3... | Answered on Feb 09, 2014
Life Fitness T3 Treadmill with Advanced Console Logo
76 questions posted
Top Life Fitness Exercise & Fitness Experts
Vincent G
Vincent G
 Edward
Edward
Thomas Perkins
Thomas Perkins
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Life Fitness Exercise & Fitness
Most Popular Question
life gear error 3
  • Exercise & Fitness
