20 Most Recent
Bladez Ion 9.9 Fold-up Treadmill Questions & Answers
We have an ION 7.9T
We have done all the above and nothing has worked still got flashing E7! Any suggestions?
Walking on tread mill is jerky. almost like some one keeps putting the break on
Hi There, have you lubricated the deck lately? does the belt glide easily over the deck with your foot pushing it and the power to the treadmill off? If the belt glides easily with your foot, but not when powered, you're motor control board could be about to fail. capacitors routinely go bad on these controllers over the years. You can find further help by emailing gregATbuyfitnessrepairpartsDOTcom
good luck!!
It's on however I go to push the buttons to start
replace the battery, and clean the contacts battery, if your model has battery. Adjust the REED switch, clean it, and tigh the connector. Test for open or faulty and replace. see the diagram attached.tight the ribbon cable inside the display, and tight the lower and upper connectorGod bless you
Fuse
normally is 15 amp, for 220vac. However you must see the if you Fuse is 20amps. Read in the metalic size the inscription,you will see the amper Fuse and replace.Remember do not replace one of cristal with some one Ceramic or viceversa.God bless you
My Ion treadmill with LCD screen has an error message
1) adjust the speed sensor, clean it, tight the connector or plugs.see the diagram2) adjust the Reed switch, clean it, and tight the plug or connector.tight the ribbon cable inside.se the diagram3) try to RUN the software calibration for diagnostic, troubleshooting, and fix it.God bless you
My ION tread mill show E1 on screen.\r\nI have
HI,
Ur treadmills motor controlling igbt may be get damaged. may be it become open. working on the electronic side of treadmill is danger for a person who is not aware of about it circuit. all the circuits inside the treadmill is live. possibility to get electric shock. from what u have said above , may be chance to have problem with ur dc motor also. check the same also. remove the motor controlling car and replace the igbt. also replace the transistors in its gate rail. refix the board ,then check. if the igbt get damaged again u have to replace the motor also.
ok
