20 Most Recent
GMC Denali 700cc Women's Road Bicycle Questions & Answers
Denali GMC 700C Women's road bike wrong tires!!!
Can you explain why you think the tires are too big? Do they NOT fit the rims? What condition was this bike in when you bought it? If the brake pads line up with the rims then the wheels are correctly sized for the frame.
What size tire tube goes in a 700x28c Denali Bike
700c tyres are bigger than 26".The tubes you need measure 700x28 (to32).This size is used in Hybrid style bikes.Make sure you get the same type of valve(Schreader are the same as car,Presta are narrower)or it won't fit the hole in your rim.
Make sure when inflating that the tube isn't trapped between the tyre and the rim.Only inflate to the pressure written on the sidewall of the tyre.
Install spear pump
Sounds like the braze ons, that's what they're called, are broken in the frame. Only thing left is to drill them out and replace them with Rivnuts. Your local bike shop should be able to handle that.
4/7/2014 12:38:47 AM •
GMC Cycling
Answered
on Apr 07, 2014
Tomahawk E Series Exercise bike loud peddling sound
Standard WD40 is just a 'quick fix' as it isn't an actual oil unless the can is clearly labelled as "Bike All Condition Lubricant". It'll be best to buy a proper light oil like 3in1, 151 Super oil or an actual chain lube.
This 'clickey' noise. Is it random and happening every so often or is it a constant, regular click that changes with the speed your pedalling at? Check for slack in the chain. as you wiggle the chain up and down there should only be about a centimetre of movement in the chain. If it's too slack or too tight it can make strange noises. Check the axle bolts and nuts to make sure they're not loose. Check the wheel is mounted straight. If it's turned left or right the chain will 'skip' as it's slightly missing the cog teeth on the wheel. Use the frame at the rear end of the wheel as reference and measure how far the side of the wheel is from the frame on both sides. It should be about the same both sides.
9/22/2023 12:16:04 PM •
Cycling
Answered
on Sep 22, 2023
New Balance 6100 Recumbent Bike making a clanking noise when pedaling
I have done a tremendous amount of research on this problem. New Balance (Fitness Quest) is out of business as of late 2012 and no parts are available. The main bearing or crank bearing set is 100% compatible with Proform part number 295560. Since New Balance put their name on this product, they have stated they will reimburse customers for the repairs.
4/5/2023 11:21:09 AM •
Cycling
Answered
on Apr 05, 2023
A manual for a manual for a Genesis model gs52686 men's bike a V2 100
Il est possible de trouver un manuel pour le v?lo Genesis GS52686 V2 100 en visitant le site web du fabricant ou en contactant directement le fabricant pour demander un manuel. Il est ?galement possible de trouver des informations sur ce v?lo sur des forums de discussion ou des sites web sp?cialis?s dans les v?los. Il est recommand? de v?rifier si le manuel est disponible en ligne ou de demander une copie imprim?e aupr?s du fabricant. Il est important de noter que les r?glages de la fourche de suspension et de la suspension arri?re peuvent varier en fonction du poids, de l'exp?rience et des pr?f?rences de conduite de chaque cycliste. Il est recommand? de consulter un m?canicien ou un expert en v?los pour obtenir des conseils sur les r?glages appropri?s pour votre v?lo.
3/14/2023 6:23:13 AM •
Cycling
Answered
on Mar 14, 2023
