20 Most Recent RentRight Property Management Software (rentright25) for PC Questions & Answers
To install RentRight and transfer you data onto a new computer?
Answer :
Follow this link to download and install RentRight v3 on your NEW computer: http://www.rent-right.com/support/UpdateVer3FirstTime.html
If you are not using the Internet, you will need to order a CD with the full version of RentRight to install into your new computer.
Follow this link to download and Update to the latest version of RentRight v3 on your OLD computer: http://www.rent-right.com/support/UpdateVer3.html
DO NOT change the installation directory folder. When asked if you want to write over the existing folder, reply, YES. Respond to the prompts to complete the installation.
When done, open RentRight on your old computer, go to File on the menu bar and choose BACK UP to back up your data, and save it to your Desktop.
TO BACKUP YOUR DATA:
Insert a portable storage device, such as a blank CD or USB memory stick, into your computer.
We recommend that you do not us a 3 1/2 floppy disk, because it is not reliable, and may not have a
large enough storage capacity to hold your backup.
In RentRight, click on File from your Menu bar
Select Backup
Click the Backup button
The Back Up window will open:
Use the "Save In" drop-down menu to navigate to the desired location, such as your Desktop
DO NOT BACK UP DIRECTLY TO YOUR PORTABLE STORAGE DEVICE
Click on the Save button
Copy the backup that you just created, rrbackv3.zip, from your saved location to the portable storage device you inserted into your computer.
Copy and Paste the Backup Database you just created, from your Desktop to a portable storage device,
such as a cd or flash drive.
Take the portable storage device containing your backup from your old computer to your new computer, and Copy and Paste the Backup Database from your portable storage device to your Desktop.
Open RentRight on your new computer, go to File, and RESTORE your data.
TO RESTORE YOUR DATA:
1. Locate your rrbackv3.zip file
2. Right-Click on your rrbackv3.zip
3. Select 'Extract All' from the drop-down menu
4. Follow the Extraction Wizard prompts. This will create a Folder with the name rrbackv3. In this folder will be a file called 'aptment.mdb'. You may not see the .mdb file extension if you do not have this preference set. This aptment.mdb file is your Backup Database, and is the one you want to restore in RentRight.
5. Start RentRight.
6. Select File from the Menu Bar.
7. Select Restore.
8. Cancel the "insert a disk into drive A" message, unless you are using a 3 1/2 inch floppy disk. If so, insert the disk.
9. Click on the drop-down arrow in the 'Files of type' field, and select 'All Files'
10. Click on the drop-down arrow in the 'Look in' field, navigate to the aptment.mdb you just extracted, and click on it.
11. Click the Restore button
KEEP IN MIND THAT YOU CANNOT BACKUP OR RESTORE DIRECTLY BETWEEN RENTRIGHT AND A PORTABLE STORAGE DEVICE.
You must backup your data to your desktop, and then copy that file from your desktop to your portable storage device, such as a disc or flash drive. The same applies for restoring from a portable storage device: you must copy that backup from your portable storage device to your desktop, and restore your data from the file copied on your desktop.
Now you need to move your license to the new computer.
You must first de-activate the license from the old computer. Go to Help/RentRight Sales on the old computer. Follow the prompts about moving from one computer to another. Next, choose the option to "Activate over the Phone". Contact us by phone at 800.964.8065 x2826, or email and provide us with the Entry Codes and Computer ID numbers for both the old and new computer. After deactivating the license on your old computer, we will give you a different activation code for the new computer.
RentRight... | Answered on Aug 22, 2011
If you own the house - it should be in the mortgage papers.. And probably in the inspection papers as well.. Most states require the year built in the paperwork..
This is also a matter of public records..
If your county has online access to public records - you can go to they're web site,, look up the public records for that property..
If they don't have the info on a website (some counties do - some dont)
you could call the county appraiser and they will be able to tell you..
There is no "online sourse" otherwise that would indicate when the house was built..
Have a great day !
RentRight... | Answered on Oct 13, 2009
can you explain your issue more clearly please,
Do you mean that, You have the Rent-right software and you want to connect it to database server without password, Am i right?
Please leave your question as comment,and we may help you
RNJ VINODKUMAR
RentRight... | Answered on Sep 28, 2009
CAT6 cables & jacks are better than CAT5E.
CAT5E cables & jacks are better than CAT5.
CAT5 cables & jacks are better than CAT3.
CAT3 cables have problems going faster than 10Mbit/second.
CAT5 cables support 100Mbit/second, and seem to work with 1000Mbit/second ("gigabit") devices.
Computers &... | Answered 1 hour ago
IF they are new, get a replacement, the wires in those are very small and subject to breaking. IF you cannot return them, get another set.
Computers &... | Answered 4 hours ago
You will need the sort code, account number and name of the account holder. If you are doing it online you need to go to your bank account details and look for payments to individuals or companies.
Computers &... | Answered 8 hours ago
Your fairy name is not a good name or your registering name is not a good one?
You can submit bugs here
Bug report
FAQ Here
FAQ
Computers &... | Answered 11 hours ago
Google is now paying $17000 to $22000 per month for working online from home. I have joined this job 2 months ago and i have earned $20544 in my first month from this job. I can say my life is changed-completely for the better! Check it out whaat i do.....
Click Here ------>>>>> www.Neway9.com
Computers &... | Answered 13 hours ago
hi Caryl.
A. Actually, the official limit is 3.4 ounces, or 100 ml. You may carry as many containers as will fit in a one-quart clear plastic "zip" bag
What size carry on for Allegiant Air? (22.9 cm x 35.6 cm x 55.9 cm). This measurement includes wheels, pockets, handles and decorations. The carry-on bag must be placed in the overhead compartment. All baggage must accompany a passenger on the flight.
Checked and Carry-on Bag Information ' Allegiant Air
https://www.allegiantair.com/baggage-1 Search for: What size carry on for Allegiant Air?
How many ounces can you take on carry on in Alligiant airline Google Search
Computers &... | Answered 14 hours ago
Hi Laura. Do you mean that your PC is not picking up your flash drive?
What operating system are you using?
Have you tried plugging it into a different USB slot?
Does it work on a different PC?
Computers &... | Answered 15 hours ago
We are a repair Forum George.
You can delete anything on your computer by highlighting it and using the delete key.
TNation seems to be a Keep Fit organisation based on Testosterone. Not sure where the profanity would be coming from? .
Computers &... | Answered 22 hours ago
what's the problem? more details please
Computers &... | Answered 23 hours ago
go to the microsoft site and search for "office"
Computers &... | Answered 24 hours ago
RentRight Property Management Software (rentright25) for PC Logo
6 questions posted
Top RentRight Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a RentRight Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • RentRight Computers & Internet
Most Popular Question
purchased new computer want
  • Computers & Internet
