20 Most Recent DeLonghi DE500 Dehumidifier Questions & Answers
6answers
E3 error
I got mine fixed tonight! It was not that easy but can be done.
After my last post, I called the customer service of DeLonghi. The agent can only refer me to the authorized repair shops but she does not know what “E3” meant. There is no shop in NJ where I live, and the closest one is in CT! One of the two shops there knows right away the E3 is the fault of a condenser sensor. He mailed me the part ($25) and I took the covers off (be very careful to record where the screws are from ---- they are not all the same size/shape, and also there are two small tabs on the top holding two cover pieces together, so don’t force it to open or you will break it). There is only one part looks like the same as the replacement part I newly obtained and it has a metal clip attached on the copper coils. Carefully replace the sensor on the coil as you find previously and plug the other end to the control board. It sounds lengthy but once you open the cover it will all become clear to you. Be patient and this can be done. Very glad to see/hear it is working now again!
p.s., the store first mailed me the wrong part (on the plug-in end it has two ridges rather than one) so I have to call them again to explain and they mailed me a different one with a single ridge. Apparently there are two types (old and new model) for this model.
8/6/2021 9:03:26 AM • DeLonghi DE500... • Answered on Aug 06, 2021
Beeping tank warning light blinking, pump light not on
I think this means your pump is not working, and therefore the tank is full. The pump could just be switched off, could have failed, or could be clogged. See the other messages regarding this model, for an excellent description of how to clean out a clogged pump.
11/30/2014 2:02:31 PM • DeLonghi DE500... • Answered on Nov 30, 2014
De500 pump failure
I agree with Mike Kolbay's earlier very complete answer. The water intake to the pump is quite narrow, and clogs easily with accumulated lint and bacterial muck. While the covers are off the machine, thoroughly clean the drip tray and all the water passages. A piece of crud the size of your smallest fingernail can cause water to overflow onto the floor, rather than going into the tank.
9/9/2014 2:29:46 PM • DeLonghi DE500... • Answered on Sep 09, 2014
4answers
DeLonghi Dehumidifier pump out failure
I have the same problem. Very annoying. My suggestion is to go to your nearest dealer and throw the unit through their front window.
7/8/2014 3:31:30 AM • DeLonghi DE500... • Answered on Jul 08, 2014
0answers
The value on the right doesn't change
If it is showing E1, E2 or E3, contact the service center. The manual can be gotten at: http://www.homedepot.com/catalog/pdfimages/2b/2b17f072-168c-4e5f-b703-d2af52c11001.pdf
5/1/2014 4:34:47 PM • DeLonghi DE500... • Answered on May 01, 2014
My des12 red light wont go off although unit is empty of water
Again!!!! Unplug machine X 15 minutes. Then fill with water. Then plug back in! If still lit, you have a water scale (mineral build up) issue that needs cleaning according to owners manual If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
1/20/2014 1:54:51 AM • DeLonghi DE500... • Answered on Jan 20, 2014
Delonghi dehumidifier overflows
these humidifiers are total junk. The sensors are cheap and get stuck or broken so easily. for your problem tho, you can either find the sensor by taking off the cover and use your hands to break free any stuff causing it to get stuck or you can drill a hole in the water tank and insert some fish tank tubing and let the water drain out as it collects.
4/26/2013 8:31:44 PM • DeLonghi DE500... • Answered on Apr 26, 2013
Delonghi Dehumidifier DE500P - Code E3
Hi Thomast5263,
I live in NJ and the nearest center is in CT. So you can imagine that I am not gonna to ship my unit! :-)
The one I got is from Hartford, CT Utility Electric Service: 860-246-7271; talk to Dana and he is very helpful. They charged me $25 and shipped me the part and it now works fine.
When I talked to Dana he sounded pretty sure it was the condensor sensor. Simply call Dana and tell him that you have an "E3" code. I do NOT know the part number or ID.
Don't open the unit until you get the new part ---- it will help you to identify the part to be replaced. After you get the part, make sure you mark down all the screws (they are not the same! so pay attention which one is where). There are two tabs on the top so be careful when get them separate apart ---- don't force it or you might break it. The sensor itself is attached/stuck in between the copper coils under a black cover. Plug another end to the control board and you are done. Apparently there are two kinds of plug-in end ---- the first part Dana shipped to me did not match the old part so he has to send me another one which worked.
The whole procedure is not that difficult, but when you are doing this the first time you just need to be patient to locate all the screws and sparate the covers. From my experience you do need to take all covers off, otherwise you can not see the part and the wire.
Good luck to you and let me know the good news!
4/26/2013 8:23:35 PM • DeLonghi DE500... • Answered on Apr 26, 2013
2answers
What does an E3 error
Condensation sensor was tripped...needs to be dried/cleaned/repaired (on lint screen side remove plastic panel. The sensor is clipped to radiator fins.
Be Safe or don't do it....
On the side with the lint screen, remove the five screws holding the top panel in place. The sensor that needs to be checked in mounted on the radiator fins. Remove the sensor and 4 pin connector. With a pin, remove the loose fitting housing the "sensor"...a circuit board that "shorts" with condensation...check corrosion and look for component damage on the oft chance the circuit board was damaged by some inappropriate poking or mechanical failure. Reassemble and replace sensor...
For a short life span...or out of warranty and only at your risk (IF have significant other or kids or pets or human DNA... don't do this...) .. guide wire through screen notch and attach to outer screen. Build fortress around exposed sensor and talk to insurance agent for a special rider...seriously be careful.
Did you? Clean screen and GENTLY clean fins of lint, etc....(vacuum's brush head should do the trick...)
Taking all appropriate safety precautions.
Here's the 100,000 (yen) tip....with humidifier unplugged, hold down the power button (green button in lower center) and plug in the appliance.
Watch the LCD screen as it conducts a self test...and wha...lah!.
4/26/2013 7:56:22 PM • DeLonghi DE500... • Answered on Apr 26, 2013
It is not taking moisture out of the air. The
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
8/13/2011 5:27:04 AM • DeLonghi DE500... • Answered on Aug 13, 2011
My dehumidifier as stopped extracting
There are 4 basic, yet solvable reasons for what you have described.
1. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
2. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
3. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
4. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
I hope this helps you troubleshoot & solve the problem. Thanks for choosing FixYa.
7/25/2011 2:53:37 PM • DeLonghi DE500... • Answered on Jul 25, 2011
My Delongi Dehumidifier makes a
To locate a a Delonghi Service Center near you, go to the following link and enter the requested information. http://delonghiusa.com/support/servicelocations
Hope this helped you.
6/29/2011 12:12:31 PM • DeLonghi DE500... • Answered on Jun 29, 2011
Humidity sensor not working correctly. Replace
The need for replacing it should be based on several things:
1. How did you determine it was the Humidity Sensor? Several other things, that are easily
solvable without having to replace parts, can mimic a faulty sensor.
2. How old is the unit? If it's 5 years old or older, it would probably be better to replace the unit,
rather than repair it.
3. Have you maintained the unit as instructed in the Owner's Manual? Regular cleaning and proper
storage when not in use, etc.
If, after answering all the above questions, you decide you want to make a DIY repair and want to order the part(s), Appliance Factory Warehouse is about the best supplier of parts out there. You can search for what you need at http://www.appliancefactoryparts.com/search/index.php
I hope this helps you to make the right decision. If I can be of further help, please contact me.
6/16/2011 2:29:52 PM • DeLonghi DE500... • Answered on Jun 16, 2011
My machine is running but no water is being
Several things can cause your problem:
Dirty or clogged air intake filter. Remove and clean the filter according to the Owner's Manual instructions.
Dirty coolant coils. Clean and dry the coolant coils.
The humidity extraction level is set to high. Lower the level to 35%
Not enough free air space around the unit. Maintain at least 12" of air space around the entire unit.
The ambient air temperature at floor level is to cold (between 40 - 60 degrees F). Raise the unit up off the floor onto something sturdy enough to handle the weight (including a full tank of water) and the vibration during operation. This happens frequently in basement applications.
Depending on the age of the unit, the refrigeration coolant may need to be recharged.
The humidity sensor has failed and needs to be replaced.
All of the above are where you start troubleshooting and hopefully solving the problem.
6/1/2011 9:00:37 PM • DeLonghi DE500... • Answered on Jun 01, 2011
How do I find an operation mnual DE500 p
Google DeLonghi Dehumidifier which will bring up the company's website. All owners manuals for all models can be found there.
6/1/2011 1:29:38 PM • DeLonghi DE500... • Answered on Jun 01, 2011
I have the Delonghi DE500P
Replacing the switch/lever is more trouble and costly than it's worth. That's if you can find the part. I suggest, that you try reinstalling the bucket very carefully, making sure it making contact with the lever in the proper position. Lots of times, the bucket is simply not being inserted properly and it misses the switch. If that doesn't work and you want to repair it yourself. Contact Delonghi Parts Dept 800-865-6330.
4/27/2011 10:45:47 PM • DeLonghi DE500... • Answered on Apr 27, 2011
DeLonghi DE500 Dehumidifier Logo
Popular Tags
61 questions posted
Top DeLonghi Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
  • DeLonghi Dehumidifiers
Most Popular Question
machine running but no water being
  • Dehumidifiers
