20 Most Recent
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Questions & Answers
Briggs and stratton 44m777 stalls
Replace the fuel lines. I had the same problem with one of my riders. The inside of the fuel lines had rotted and they were collapsing when they tried to suck the gas through them.
New lines and it ran all day!
10/15/2023 8:07:41 PM •
Briggs &...
Answered
on Oct 15, 2023
Plug gap 675e series
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwi0mN-q5oH9AhVlkYkEHXKoAlsQFnoECBAQAQ&url=https%3A%2F%2Fwww.fixya.com%2Fsupport%2Ft26697256-plug_gap_675e_series&usg=AOvVaw38_uBSYnpY_8gFFpkWJTgR
2/6/2023 9:06:15 PM •
Briggs &...
Answered
on Feb 06, 2023
My craftsman 20hp mower ran for 15 minutes with
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiejZiJ5oH9AhXsk4kEHWSSDWYQwqsBegQICBAF&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DA23nERLrBAk&usg=AOvVaw0Np1nZ7kKaEqNAp1FbmueT
2/6/2023 9:05:10 PM •
Briggs &...
Answered
on Feb 06, 2023
I have a troy built
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjPwu3B5YH9AhVqkYkEHRwKCAIQFnoECAUQAQ&url=https%3A%2F%2Fwww.fixya.com%2Fsupport%2Ft5979403-troy_built&usg=AOvVaw0b3wiQJvQu7Er6dxxb4OY8
2/6/2023 9:03:25 PM •
Briggs &...
Answered
on Feb 06, 2023
Blowing oil out of the exhaust 18hp intek oh
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjp1p2k5YH9AhW_jYkEHTR1D_QQwqsBegQIBxAF&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DZDVEZ0LkUfc&usg=AOvVaw1rd1buY3OdXZyXvayWD93B
2/6/2023 9:01:24 PM •
Briggs &...
Answered
on Feb 06, 2023
Carburetor flooding
Not familiar with this model, but this is exactly how the smaller ones behave when the carburetor diaphragm is shot. Larger engines usually have a float system with needle and seat in which case the problem is either a leaking needle/seat assembly or saturated float.
5/4/2022 2:39:28 PM •
Briggs &...
Answered
on May 04, 2022
What are the torque specs on intake manifold on Briggs & stratton
if there is thread locking compound on bolt or threads it must be removed, use a tap to clean the threads and a wire brush to clean the bolts. Use a thread locking compound (blue) when reassembling, torque the bolts to 30 ft. lbs. alternating bolt to bolt in 7-10 lb. increments. Recheck the torque after the engine has been ran up to op temp.
10/10/2019 7:15:12 PM •
Briggs &...
Answered
on Oct 10, 2019
The govenor rod cannot be adjusted. The springs
Just guessing here, but if there is no control of the throttle and the engine over revs, then more than likely the governor control is broke. Briggs if famous for that problem. Governor is around 25 dollars and a lower crankcase gasket. Requires the engine to be pulled, lower crankcase removed, remove all pieces of old governor and then re assemble with new governor and gasket.////Before doing all this check that both springs are on the governor on the exterior of motor. If you manually hold the governor arm back, counterclockwise, and it still revs, then you need to replace governor. Don't let it rev for long or it with throw a pushrod or worse. good luck
5/29/2019 12:00:28 AM •
Briggs &...
Answered
on May 29, 2019
My 24 hp intek is only running on one cylinder
Are you sure both magnetos are good? did you try swithing them to see if it reverts to the other cylinder. If that's not it I'd expect a stuck valve,or the adjustment came loose. Take valve cover off and make sure both are moving..
4/30/2019 6:07:52 PM •
Briggs &...
Answered
on Apr 30, 2019
