20 Most Recent
Stanley Bostitch N80s Nailer -rebuild Parts O`ring & Seal Kit Questions & Answers
The nails don't advance to the fireing pin
Assuming that the nails are moving ok down the rails and the pusher is in good order, if the driver does not return to the top position, the nails will not move into position. Remove air line to gun. Use metal rod to push driver to top position and verify that nails move into position. If the driver was at the top position, check for debris in rails or wrong nails. Place a strip of nails on the outside of the rails and align the nail heads with the rails. The first nail should align with the path of the driver. If the first nail head is tilted back away from the path of the driver, the driver will just push nails back into the rails and slip past. If nails are correct and driver does not return to top, suspect worn piston oring or cracked lower bumper or lack of lubrication.
Manuals knowledge center
Bostitch nailers are usually stamped with model number on the lower body just above the nose piece on the left side (holding gun with right hand). Sometimes this stamping is covered with paint or the number was so lightly stamped that it is hard to see. Good luck
My nailer doesn't have the power it used to. the
If it is a nailing hammer for a roofing project, I have used a degreaser to spray the end. Even on my air nailers that I use 16d nails in I do this. Make sure you keep 3 drops of the (FOR THE NAILER) IN IT'S RECEIVING END EVERY DAY! This will keep the inside good and slick.
Can I use paper collated nails in my Sta
Paper collated will work. Maze nails part # PCP28325131 works on many 28 degree guns including yours. Only advantage that I can see with using welded is that the nails will take more abuse on the job site including getting wet. Paper collated can brake apart easily but dont worry too much about the difference. I would buy the least expensive or available but I like the idea of using made in USA of maze nails (not available on all areas of US). Good luck
Leaking air through trigger area.
The trigger valve has seven orings. The oring kit may not include all orings needed. To replace the trigger valve, remove nails, remove the rollpin holding the trigger with 3mm driver to expose the trigger valve. Next remove one or two roll pins holding the trigger valve in the body of the gun. Apply air pressure to gun and catch the valve with gloved hand (use caution because the valve may come out with force). Note the position of the valve in the body of the gun in relation to the roll pins. If the firing pin seems loose in the body of the valve, replace the whole valve(could be # tva6 cost about 20 dollars on ebay). Good luck
Bostitch n80s nail gun leaks
under my name click on it and in the tip section on the left hand side of the page you will find detailed instructions on how to remove this valve. If you have trouble finding it let me know and if I have helped you with your problem would you please vote accordingly, Thank you
My Bostich n 80 nailer misfires / doesn't always
Given your description, there are a couple of distinct issues here:
1) The gun mis-fires. This is usually due to a leak in either an Oring or the trigger itself. Both can be replaced for a reasonable cost. Follow the link below to get more information about a site that has parts breakdown diagrams and numbers.
2) The not feeding is usually caused by a lack of lubrication at the feeder area. It is also possible that dirt has accumulated here and has jammed the plunger assembly. I have successfully cleared this up in my guns by applying oil directly onto the plunger and working it a few times by hand. Please note that this should be done WITHOUT any air connected. Fire the gun a few times empty against a piece of scrap wood to test it as well.
Hope this helps,
Dan
Link:
http://www.fixya.com/support/r5812776-bostitch_nailgun_dis_assembly_assembly
Air is leaking at the trigger on a Bostitch 80s b1
Your nailer uses a trigger valve (could be part # tva6 cost about $20, need to look up) and is sold at www.bostitch.com or generic valves sold on ebay . If you have a source for orings, you could try to repair the valve. Remove the roll pin that holds the trigger to expose the tva6 valve. There are roll pin/pins that hold the valve in just above the valve in the body. Remove these pins and apply air pressure to gun to pop-out the valve. Use caution when you do this. Remove nails, lower pressure to gun and use glove or rag to catch valve because it could come out with force. With tva6 valve in hand remove two pins that hold valve together and remove inner plunger. The middle oring on plunger is cause of leak. Try using an oring about same size as the broken seat. It must fit pretty tight to work. If you had a small leak it could be that the firing pin orings fit too loose or just too worn. Use silicone lube or oring lube on the orings and the valve port. Good Luck on your repair and email if you have other questions
My bostich framing nailer leaks air from top and
do you already have the rebuild kit??. Could be a cut o ring the cylinder seal might be cracked , there are quite a few items to check, specifically where is the air coming from, the exhaust, if so then I would look for the items mentioned. It would be best to download a breakdown for the tool and if you are mechanically inclined start disassembly laying parts out in the order removed and also maybe take a few quick pics to help you in reassembly. they are not that hard to rebuild. Let me know and I will see about the breakdown and rebuild kit for you but I need the model number and give me some general area you are in and I will try and find parts somewhat locally
Air leaking out of the
Your nailer uses a trigger valve (part # tva6 cost about $20) and is sold at www.bostitch.com or generic valves sold on ebay . If you have a source for orings, you could try to repair the valve. Remove the roll pin that holds the trigger to expose the tva6 valve. There are roll pin/pins that hold the valve in just above the valve in the body. Remove these pins and apply air pressure to gun to pop-out the valve. Use caution when you do this. Remove nails, lower pressure to gun and use glove or rag to catch valve because it could come out with force. With tva6 valve in hand remove two pins that hold valve together and remove inner plunger. The middle oring on plunger is cause of leak. Try using an oring about same size as the broken seat. It must fit pretty tight to work. If you had a small leak it could be that the firing pin orings fit too loose or just too worn. Use silicone lube or oring lube on the orings and the valve port. Good Luck on your repair and email if you have other questions.
Need to know how to repair and repace head air
Can I suggest that yo go to Bostitch.com and download a schematic for that tool. with that in front of you it is quite simple. Make sure that when replacing the o rings that you lubricate them. Let me know if you have trouble I have worked on them for years.
