20 Most Recent
Dewalt D25940K Heavy Duty Demolition Hammer With 3/4 Inch Hex Steel Drive System Questions & Answers
I am having tuff time getting bit tolockin I dont
The bit should have one flat spot. There are several types of bits. the most common ones are SDS and Spline.
Align the flat of the bit with the yellow triangle and black hexagon on the side of the tool holder sleeve. Must pull back tool holder sleeve to insert bit fully.
Fully insert the bit shank into the chuck. If tool holder sleeve does not spring into original position, the bit is inserted incorrectly.
I will continue to do some more research on that particular model to find the particular bit type. Please provide a rating if this has been of any help. Good Luck and have a Great Day.
Dewalt D55168 225 PSI Air compressor: What are the preset pressure limits for this model? Is it actually 225 - 180?
https://www.manualslib.com/manual/494085/Dewalt-D55168.htmlSpecifncationsMODEL D55168WEIGHT 88 Ibs. (39.92 kg)HEIGHT 41.75" (1060.5mm)WIDTH 19.0" (4826 mm)LENGTH 21.25 (539.8 ram)AIRTANK CAPACITY (GALLONS) 15 Gallon (56.8 fiters)APPROX CUT-_N PRESSURE 160 PSI (1103.2 kPa)APPROX. CUT-OUT PRESSURE 200 PSI (1379.0 kPa)SCFM @ 90 PSI (620.5 kPa_ 5._cant get fixya comment to work so will edit here...The 200/160 are the typical DS55168 settings from factory and meet the 90 psi @ 5.4 cfm rating.Pressures can be adjusted to a MAXIMUM 225/185 with a resulting lower cfm rate.I'm not familiar with "type 9". Likely nothing special just different setting from factory?
