20 Most Recent
Callaway Quartz Golf Watch Questions & Answers
I bought a Callaway CY2130
at the sides of the stainless steel bracelet near the lock you will see holes its a small screw, use a small screw for this. just be careful with your hand.
Dont know how to change the battery in my callaway
Thank you for contacting Fixya.
Locate a very small tab (or recessed area) on the edge of the back cover. This is the access point for removal. You can find this sometimes by running your fingernail around the back rim, as this tab or indentation can be hard to see.
Pull out the stem, which releases the back on some watches.
Get a small flathead screwdriver it needs to be a thin inflexible tip. Use a kitchen knife as a last resort. Wrap the hand you are holding the watch with in a towel or protect your hand in some manner so you don't injure yourself if the screwdriver/knife slips.
Very carefully slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has). Do not attempt to insert the point of the knife. Use the length of the blade.
Get under the tab or recessed area and gently but firmly turn the blade upward, popping the cover off.
When you replace the cover, make sure you line up the stem slot on the cover with the stem of the watch.
Best regards. Jewel
