20 Most Recent Cuisinart ICE-40 Flavor Duo Frozen Yogurt 1 Quart Ice Cream Maker Questions & Answers
DID YOU USE SALT IN THE ICE ??
Cuisinart ICE-40... | Answered on Jan 28, 2010
Hi -You can download the manual from the following link:
http://www.cuisinart.com/manuals/index.php?item_id=985
Good Luck!
Cuisinart ICE-40... | Answered on Jul 01, 2008
Additives and air.
Gums, emulsifiers and stabilizers are commonly added to commercial ice cream, and generally there is more air whipped into the commercial ice cream during freezing in the manufacturing process.
Cuisinart Ice... | Answered on Nov 17, 2019
Try Googling (Cuisinart)(CIM-605A)(manual) without parens.
Cuisinart Ice... | Answered on Mar 21, 2018
First you can not run this machine on 220 Volts, it probably burnt up the motor and every thing else on it. The only way you can use a 110 volt unit on 220 is to buy a step down trans former and install it which will take the 220 down to 110.
Cuisinart Ice... | Answered on Feb 05, 2018
Fixya does not sell timer knobs. Check with a local appliance parts supplier.
Cuisinart Ice... | Answered on Oct 19, 2016
The bearing or bush of the motor would be faulty. try to put some oil on the shaft.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Cuisinart Ice... | Answered on Jun 10, 2016
I had one do that and I opened the gear box and found that the last time we made ice cream & it started getting hard the motor caused the gear to pop a tooth off (plastic). so now you hear the motor running but no transmission. Take it apart and check or turn the ice cream tub connection socket 1/4 turn and see if that makes a difference.
Cuisinart Ice... | Answered on Nov 18, 2015
Cuisinart ICE-40 Flavor Duo Frozen Yogurt 1 Quart Ice Cream Maker Logo
2 questions posted
Top Cuisinart Ice Cream Makers Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Cuisinart Ice Cream Maker Expert? Answer questions, earn points and help others
View Most Popular
  • Cuisinart Ice Cream Makers
Most Popular Question
ice cream thicken
  • Ice Cream Makers
