20 Most Recent
Cuisinart ICE-50BC 1.5 Quart Ice Cream Maker Questions & Answers
Repair motor arm or make my own
I run mine in an unoccupied room with an old hardcover book and a quart soup can on top. Just a noisy beast but great ice creame when you figure out how to use it.
Parts can be found here:
http://www.cuisinart.com/parts/ice_cream/ice-50bc.html
11/7/2013 2:02:28 AM •
Cuisinart...
Answered
on Nov 07, 2013
I am in need of a knob to the Cuisinart ICE-50BC
I just got this from Cuisinart. I ordered 5 units so I would have some spares.Thank you for your inquiry. The part number for the Timer Knob that goes with the ICE-50BC is ICE-50BCTK and is available for $3.00 plus shipping and any applicable tax.We welcome you to contact our Customer Service Department at 1-800-726-0190, if you prefer. We will gladly place the order for you. The hours of operation are 7 AM -11 PM EST Monday through Friday and 9 AM - 5:30 PM on Saturdays and Sundays, excluding major holidays.
8/8/2013 5:57:08 PM •
Cuisinart...
Answered
on Aug 08, 2013
I accidentally washed the cuisinart ice cream bowl
Hi, I always wash the bowl in hot water, would not have it any other way for hygiene reasons & have never had a problem. After all it is only made of aluminium ! What has happened to yours to make you think you have a problem ?
Peter.
6/29/2011 2:55:08 AM •
Cuisinart...
Answered
on Jun 29, 2011
Hi, I hav bought an ICE-50BC ice cream maker. It
See the BOLD section below..
You need a good simple recipe. So here is one.
(This is an unpasteurized recipe unless you boil the blended strawberries, wash the berries very well if you don't)
1 lb fresh strawberries (ripe is better)
3/4 cup sugar (most folks double this but i prefer the taste of strawberry)
3/4 cup whipping creme
2 1/4 cups milk (2%)
1 tsp lemon juice
Liquefy the strawberries in your blender. (Boil now if pasteurizing) and add the rest of the ingredients and blend.
You
now have enough Ice cream mix for two partial batches. Divide mix in
two equal portions. You should have enough to fill machines bucket 1/2 -
2/3 full.
IMPORTANT
Do NOT have more or less in the bucket as the machine screws up with more or less of any mix.
Insert Paddle and put noisy grey power arm on top.
Add a 2 inch thick hardcover novel on top of arm above bucket.
Add a heavy Soup can on top of this book (I recommend Habitant French Canadian Pea Soup 28 fl oz size).
Set timer to 40 minutes.
Leave room as it is a noisy little beast machine.
Come back and check just before it is done. If still too liquid add 5 minutes to timer.
Empty into bowl and add 2nd half of mix to bucket.
Clean
the dimple on bottom of mixer paddle before putting back in bucket.
This batch should take 5 minutes less as compressor is already cold.
Have fun.
The book and Soup can are essential to keep the silly beasts power arm from lifting up too early.
6/28/2011 7:32:24 PM •
Cuisinart...
Answered
on Jun 28, 2011
Ice cream maker doesn't chill
The machine must be upright for 24 hours before using it.
If it was stored on its side or upside down you MUST wait 24 hours with the machine in the correct upright position. The 'person' who delivered mine made sure he tumbled it over and over again scanning shipping labels even though it said everywhere fragile and this side up.
If the machine does not work at cooling after 24 hours there is a problem and it should be returned.
Do not expect rock hard ice cream, but thick scoop-able medium firm soft-serve is easy to get as a result. A few hours in the freezer will harden it more.
6/27/2011 2:41:46 AM •
Cuisinart...
Answered
on Jun 27, 2011
Hi im looking for a replacement plastic bowl cover
Hi Barry
you will have to contact cuisinart or local service agent for one in your country.
Unless you are lucky and find one on ebay.
Please dont forget to vote this answer was helpful
Many thanks
2/17/2011 5:53:24 PM •
Cuisinart...
Answered
on Feb 17, 2011
Motor Arm stopped working
All i can suggest is cleaning the contacts. Clean the metal prongs and the two holes they go into.
UNPLUG THE MACHINE
Use a q-tip cotton swab dipped in hydrogen peroxide or rubbing alcohol ... not both. After cleaning one hole wipe off any excess fluid before cleaning the other hole. These holes are a natural for catching stray drips of food or other kitchen goo.
Good luck.
8/20/2010 4:32:50 AM •
Cuisinart...
Answered
on Aug 20, 2010
How to make icecream in cuisinart ice 50bc
1 tsp lemon juice
You now have enough Ice cream mix for two partial batches. Divide mix in two equal portions. You should have enough to fill machines bucket 1/2 - 2/3 full.
IMPORTANT
Clean the dimple on bottom of mixer paddle before putting back in bucket. This batch should take 5 minutes less as compressor is already cold.
Have fun.
8/20/2010 4:09:17 AM •
Cuisinart...
Answered
on Aug 20, 2010
To much of yogurt or
Use a silicon jiffer (rubber spatula to get stuff from walls of jars) to get it off walls and into bowl. You can also warm the bowl with warm/hot water on the outside and slide it out.
Do not use metal or it will scratch. Abrasive cleansers and scrubbing cloths will do this too ... so no steel wool please.
8/20/2010 3:45:56 AM •
Cuisinart...
Answered
on Aug 20, 2010
Ice-cream maker doesn't fit together
Do a 1/2 to 2/3 batch. Put a book and a soup can on top of the mixing arm to keep it down.
The machine does make wonderful Ice cream, however it is noisy and fiddly. Do not try the full batch as it just doesn't work. I find doing 2 half size batches works best. Also find a spare room to run the noisy beast in.
8/14/2010 4:26:50 AM •
Cuisinart...
Answered
on Aug 14, 2010
