20 Most Recent
Hitachi DS18DFL 18V 1.5Ah Lithium Ion Driver Drill Questions & Answers
A bit is stuck in my cordless Hitachi DS18DFL
There are always 2 different rings to the chuck grip surface, you always hold the back one and turn the front one counter clockwise.
You should be able to do this by hand.
But if it is really tight for some reason, you could use a channel lock pliers or even a pipe wrench if you had to, but both might leave some marks.
Gears slipping
Many of these have a torque clutch that is used in screwdriver mode that will slip when a certain torque is reached as set by the ring around the chuck area. If you want it to not slip, usually you set it on a symbol that looks like a twist drill.
Hitachi DS18DFL, just stops after seconds of use???
time to replace the battery. eventually they won't keep a full charge anymore. they have a memory. if it's 100% charged, and you use 90% or the charge then charge it, it'll only let you run 90% of it next time. you lose 10% of the charge capacity.
