20 Most Recent Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1 Questions & Answers
Briggs & Stratton 23 HP VANGUARD. The right side runs cold?
Question edited for clarity and make sentences.Question moved form Cars and Trucks to make model category.My guess is you have a leaking valve. The compressed air in the leak down test is closing it. Remove the heads and lap the valves. Check the valve stems are true and not sticking. The variation is compression 50 v 30 is too great.https://www.google.com/search?q=Briggs+%26+Stratton+23+HP+VANGUARD.+right+side+runs+cold..
8/20/2023 5:49:23 PM • Briggs &... • Answered on Aug 20, 2023
What is the valve clearance on 23 horse brigs
The solenoid on carb was bad causing reduced gas to motor and low power
9/30/2019 12:07:54 AM • Briggs &... • Answered on Sep 30, 2019
37 horsepower vanguard voltage regulator what voltage is supposed to go to stator and what voltage should be at the other end while running
Motorcycles are usually fitted with a permanent magnet rotor type alternator that supplies a 3 phase alternating current to a combined rectifier/regulator, the DC output of which should be sufficient to charge the battery and supply enough current to power all the ancillary equipment. A fully charged 12 volt battery in good health has a terminal voltage of 13.2 and the output of the regulator should be in excess of that or half for six volt systems. Some motorcycle systems can be remarkably complex so it is best to use a wiring diagram to aid understanding. Motorcycle batteries won't tolerate a sustained high rate of charge so some systems provide a reduced supply until the headlamp is switched on - just one of the many possible complications that could be encountered with motorcycle electrical systems, ballasted rear lights is another...
9/27/2018 10:33:33 PM • Briggs &... • Answered on Sep 27, 2018
Briggs @ stratton lawn mower engin 12 h.p.
Ring problems will do this
12/27/2017 5:28:27 AM • Briggs &... • Answered on Dec 27, 2017
I have a 16hp v twin on a prusserwasher that bogs down under load
Check for intake leaks. restricted fuel line. air cleaner anf fuel filter.
11/18/2017 5:23:30 PM • Briggs &... • Answered on Nov 18, 2017
How to check the charging system on a briggs
Check batt voltage, start then disconnect batt. connect voltmeter between pos. cale and battery voltage should read 12.6 and then 13.6 when testing voltage.
11/18/2017 5:21:48 PM • Briggs &... • Answered on Nov 18, 2017
I have vanguard 16 hp and just change the oil and both filters oil and air and now just run fine but after like five minutes is very hot
The engine is not getting enough fuel. Lean burn=overhot engine.
11/18/2017 5:18:54 PM • Briggs &... • Answered on Nov 18, 2017
18 hp Briggs blowing oil into the air filter
Sounds like your valves are sticking, possibly bent w/piston damage.
11/18/2017 5:17:57 PM • Briggs &... • Answered on Nov 18, 2017
Vanguard 12.5hp vtwin only runs on 1 cylinder
Replace coil
11/18/2017 5:15:50 PM • Briggs &... • Answered on Nov 18, 2017
My lawn mower keeps fouling plugs
Your choke is stuck
11/18/2017 5:15:04 PM • Briggs &... • Answered on Nov 18, 2017
Breather blowing oil out
If there is a check valve in the breather it may be stuck. However this is usually indicative of broken rings or burned pistons(piston) . Compression bypasses rings and pistons causing excess crankcase pressure and oil spillage.
11/18/2017 5:09:39 PM • Briggs &... • Answered on Nov 18, 2017
I have a briggs 22 hp vertical ohv that is about 6
It will give you a bit more service. However one should also replace bearings in crank and rod. I would purchase a new 6 hp from harbor freight for $100 BUCKS.
11/18/2017 3:42:02 PM • Briggs &... • Answered on Nov 18, 2017
Hello, I have a Zero
I think you have the rocker arm clearance set wrong on the one that you worked on. See if this video will help - Lawn Mower Repair Valve Adjustment Twin
9/17/2017 3:27:32 AM • Briggs &... • Answered on Sep 17, 2017
Briggs stratton,16 H>P> runs smooth 'til mower is engaged.
Is the choke staying on perhaps? check spark and plug check airflow, get compression test maybe the oil/compression rings giving way... sounds like its getting hot and increasing fuel flow for some reason??? perhaps clean carb with some cleaner while running (remove air cleaner) spray directly into carby while running run at full throttle as you spray it will try and die ... relax on the spraying and see how it goes.. check air cleaner for blockages as the same time :) hope you get it working!
5/4/2017 10:17:35 AM • Briggs &... • Answered on May 04, 2017
Torque specs. for a briggs @ stratton 24hp. head bolts
WHAT IS THE VALVE CLEARANCE ON A 23 HP. BRIGS MOTOR AND THE TORQUE ON THE HEAD BOLTS?
11/21/2016 7:37:00 PM • Briggs &... • Answered on Nov 21, 2016
3answers
My 20hp twin cylinder briggs and stratton diamond
wtha u probliam Plz Halp Me My Id faxebook Haked
2/4/2016 8:24:37 PM • Briggs &... • Answered on Feb 04, 2016
2answers
18 hp v twin will not run. It is gettng fuel to
There is a solonoid valve in the carburator that shuts off fuel to meet emissions standards. Be sure it is wired to be powered when key is in run position. You can hear a "click" at the carb. when the solonoid powers up.
2/4/2016 7:23:10 PM • Briggs &... • Answered on Feb 04, 2016
Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1 Logo
271 questions posted
Top Briggs & Stratton Tools & Hardware - Others Experts
CJ Rock
CJ Rock
john h
ADMIN Andrew
ADMIN Andrew
Are you a Briggs & Stratton Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Briggs & Stratton Tools & Hardware - Others
Most Popular Question
backfires
  • Tools & Hardware - Others
