20 Most Recent
Dewalt 18 Volt Xrp Heavy Duty Hammer Drill Kit Questions & Answers
I HAVE A DEWALT 511
Open the chuck fully and look inside, there should be a screw there that has to be removed to remove the chuck in view of the fact that it is a reversable drill and the chuck cannot be screwed off like a conventional inudirectional drill.
Dewalt xrp stuck in hammer
I am assuming you are talking about
not being able to move the "Mode Control Collar" and unless you can
get it out of hammer mode, you will not be able to change the torque collar
either.
If you feel comfortable taking it
apart AND its no longer under warranty, my best guess without seeing the tool will
be part# N026313 Gear Case Assembly. It costs about $80.00 US
Hopefully its under warranty, if so
you can go to
http://servicenet.dewalt.com/ServiceCenter/Search
to locate nearest service center.
Good luck
Sorry I wasn
I want to recieve an
Hi i have supplied a drawing and a parts list link to the drawing for you here:
http://service.dewalt.co.uk/Products/ProductParts.aspx?ProductID=5306
Hope that was ok.
How do you remove the keyless chuck
There is a screw in the bottom of the inside of the chuck. You have to loosen it with a quick, sudden turn while keeping pressure( as the chuck wants to turn with it). Putting the drill in its slowest gear helps increase resistance some.
Bit of a nuisance, really but what can you do:)
Regards, Farmerbear at FixYa.com
Put drill in revcerse and
Yup, that is what happens. You can lessen that by really cranking it down, but it is an issue with most hand tightened chucks, and does not indicate a mechanical failure. I sometimes miss my old, heavy Milwaukee wrist-breaker with the keyed chuck. If it is just too much to live with, you could get a drill with the click in hex chuck or put a Jacobs keyed chuck on your hammer drill.
Anyway, I hear where you are coming from and share your frustration.
Regards, Farmerbear
How do you put the drill bits on this drill?
Grab hold of the sides of the check and run it in revers to open the chuck and then place the drill bit in the chuck and run it forward while holding the side of the chuck to tighten it on the bit...
heatman101
Won't hold charge!
have you already called dewalt this should be under warrenty for fix or new one.lowes carrys them and will take back or give vendor #
When ever I put on my battery on my dewalt charger the indicator light blinks faster than normal while charging
Possible reasons for this behavior:
Blinks Long (Red Light): If your battery is too hot, the charger will blink the red light rapidly and for an extended duration. To prevent this, ensure that your battery is not exposed to direct sunlight or excessive heat. Give it some rest to cool down.
Blinks Short: If the battery is too cold, it will blink short and fast. This could be due to prolonged exposure to cold temperatures or the battery being idle for an extended period. Allow the battery to charge for a while or bring it to room temperature to resolve this issue.
Blinks Very Fast (Doesn't Go Away): If the light is blinking very fast and persists, it indicates that your battery has gone bad and needs replacement.
I have a DeWalt D2570 - GB. Stopped working. On disassembly I found a bare wire from the capacitor. Where should it go?
A photo would greatly help with your issue, are both wires still attached to the capacitor?? in not, the capacitor must be replaced with one of the same value,
if the capacitor is ok, look for a wire with solder on the end but nothing else attached to it, or a solder point on a card with a hole in it or a solder joint that has broken free from the card,,, if you can solder well, and have the equipment,. it is good at this point because You'll need to re-solder them back together,,
again a photo will help me greatly in telling you exactly how to fix
