20 Most Recent Hitachi Dv18dl 1/2 18v Hammer Drill/battery/charger Questions & Answers
HI,my Hitachi 18v DV18DL Hammer drill will only
the triger contacts could be fouled. clean the contacts if it doesn"t work you can order a new trigger assembly from hitachi---ACE hardware may even carry this
12/30/2010 2:45:30 AM • Hitachi Dv18dl... • Answered on Dec 30, 2010
My drillwill work in second gear but makes a noise
!st gear, gears are stripped...
heatman101
8/27/2010 2:16:22 PM • Hitachi Dv18dl... • Answered on Aug 27, 2010
Charger light flashes with no battery charging. I
The charger is damaged. Return it to the place of purchase and demand a refund or replacement. If you paid by credit card call the credit card company and cancel that transaction.
2/25/2010 6:03:44 PM • Hitachi Dv18dl... • Answered on Feb 25, 2010
I have a 18v Hitachi 3ah battery which works fine
Batterys are not necessarily universal even withing voltage ratings by make and model. A bone of contention for many users for many years.
Rigid and Ryobi are two companies that have use standard batteries for their tool line. Consider this when making future tool purchasing decisions.
Thanks for your interest in FixYa.com
2/15/2010 3:55:11 PM • Hitachi Dv18dl... • Answered on Feb 15, 2010
Battery charger doesn't charge. light blinking
Plug in the charger and then being careful to only touch one contact with one lead use an ohm/voltage meter to check the voltage and see if the charger is putting out any voltage.
11/29/2009 2:40:06 AM • Hitachi Dv18dl... • Answered on Nov 29, 2009
Torque settings freewheeled 2 days now locked on
on the gear box where you locate the torque setting/drill/hammer mark;
beneath that is a flattened spring in the shape of
,-----^-----, you have to remove the gear box and motor from the case
under the inverted V may have been a piece of hard plastic(i found a piece of plastic that looked like it would fit but had been pinched when
the original spring had split at the inverted V
11/23/2009 1:28:36 PM • Hitachi Dv18dl... • Answered on Nov 23, 2009
I have a ds18dfl hitachi drill and i want to up grade to a better chuck . do you have any advice for a upgrade?
The OEM chuck for that is about 45 dollars. There are no substitutes offered.
5/9/2020 11:39:54 PM • Hitachi Drills • Answered on May 09, 2020
Hitachi tool charger UC 18ygsl, no light, will not charge battery. Was working fine until I went to charge a battery..then light went out
If its not an bad soldering or an passive component , beware almost all brands wenn ordering an electric part for a charger its almost always more expensive then a complete (new charger ) the latest years there are more and more remplacement options to the customer , if there are defect components that are not made for ordering on marketing technical reasons and safety and more reasons. mosnfets (passive component almost sometimes fuse resistors but smd components to repair is not meaningfull . when termical defects are hidden.
1/18/2019 3:01:48 AM • Hitachi Drills • Answered on Jan 18, 2019
Are the brushes in a Hitachi DV18DCL2 impact drill driver, replaceable
Generally the answer is yes for most models. Check the manual.
4/13/2018 3:59:03 PM • Hitachi Drills • Answered on Apr 13, 2018
Hitachi cordless DS 18DGL is stuck closed and cannot release
Leave the part that is stuck in a jar with petrol overnight and then put it in a vice and try then to open then with spanner at the end of the chuck hope this helps
2/18/2018 5:33:46 PM • Hitachi Drills • Answered on Feb 18, 2018
How to remove a drill chuck from an Hitachi corded drill
How to Remove Drill Chuck If there is screw in inside center of chuck remove it, it is probably left hand threads so pretend you are tightening it and it will come free. open chuck fully and insert chuck key into holes and hit it with a hammer to remove it.
10/12/2017 6:46:05 PM • Hitachi Drills • Answered on Oct 12, 2017
Where is the serial number on a hitachi DV18DGL combi drill
Replacement HITACHI DV 18DGL battery pack 100% compatible with the original DV 18DGL battery, high quality, wholesale price. http://www.drillbattery.com.au/buybattery.php/hitachi_DV+18DGL_power+tool+battery.html
7/21/2017 1:49:03 PM • Hitachi Drills • Answered on Jul 21, 2017
Any one know where a chuck for Hitachi Power Tools Ds14dvf3 can be purchased, it is a discontinued item, and no parts seem to be around? OR is there a universal chuck that could be used in this drill?
I'm hoping you mean a chuck "key" .... there are only 4 different sizes and can be bought in tool stores as universal chuck keys tool 4 in 1 tool...
5/15/2017 4:29:25 PM • Hitachi Drills • Answered on May 15, 2017
Hitachi Dv18dl 1/2 18v Hammer Drill/battery/charger Logo
10 questions posted
Top Hitachi Drills Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Are you a Hitachi Drill Expert? Answer questions, earn points and help others
View Most Popular
Hitachi Drills
  • Hitachi Drills
Most Popular Question
charger light flashes no battery
  • Drills
