20 Most Recent Dewalt 18 Volt Dc988 Hammer Drill,dc825 Impact 18v Questions & Answers
My Dewalt 991 14.4 volt
Just buy a new Makita 18volt.
10/2/2017 9:30:09 PM • Dewalt 18 Volt... • Answered on Oct 02, 2017
3answers
Need repair schematics for dc988 dewalt cordless
web search-dewalt dc988 schematics-click on 2nd site,{parts list and diagrams
3/18/2015 8:10:47 AM • Dewalt 18 Volt... • Answered on Mar 18, 2015
0answers
What star sized screwdriver do you use to take apart a dewalt cordless drill
usually it is a 10 or 15 on the housing and then on the gearcase usually a 20
2/8/2012 5:49:10 PM • Dewalt 18 Volt... • Answered on Feb 08, 2012
Owners manual needed for my dc825 dewalt impact
You can get the manual on the link below. Upper right corner next to the tool.
http://servicenet.dewalt.com/Products/Detail/DC825B
10/12/2011 11:30:48 PM • Dewalt 18 Volt... • Answered on Oct 12, 2011
0answers
My Dewalt 927 quit working after using it
check that it isnt lock halfway between forward and reverse,iv seen it happen.
3/30/2010 7:00:13 AM • Dewalt 18 Volt... • Answered on Mar 30, 2010
Dewalt cordless drill dc988- drill motor works
Test the brushes by catching it in a stalled condition when you have it triggered, then rotate it slightly. If it takes off suspect the brushes or a dead segment on the comutator.
If it doesn't respond to this, then consider the VSR trigger... open it and test by bypassing it when in stalled condition...
3/20/2010 3:51:24 AM • Dewalt 18 Volt... • Answered on Mar 20, 2010
Need diagram to reinstall tranny fell apart when for dc988
http://www.ereplacementparts.com/
Try this place, one of the sites I use for documentation.
11/27/2009 8:16:20 PM • Dewalt 18 Volt... • Answered on Nov 27, 2009
Hi,drill started stopping and going and has now
Replacing the brushes would be the first step. You can find them on E-Bay and is easy to replace.
8/22/2009 4:10:37 PM • Dewalt 18 Volt... • Answered on Aug 22, 2009
When ever I put on my battery on my dewalt charger the indicator light blinks faster than normal while charging
Possible reasons for this behavior: Blinks Long (Red Light): If your battery is too hot, the charger will blink the red light rapidly and for an extended duration. To prevent this, ensure that your battery is not exposed to direct sunlight or excessive heat. Give it some rest to cool down. Blinks Short: If the battery is too cold, it will blink short and fast. This could be due to prolonged exposure to cold temperatures or the battery being idle for an extended period. Allow the battery to charge for a while or bring it to room temperature to resolve this issue. Blinks Very Fast (Doesn't Go Away): If the light is blinking very fast and persists, it indicates that your battery has gone bad and needs replacement.
4/16/2024 5:36:07 AM • Dewalt Drills • Answered 2 days ago
I have a DeWalt D2570 - GB. Stopped working. On disassembly I found a bare wire from the capacitor. Where should it go?
A photo would greatly help with your issue, are both wires still attached to the capacitor?? in not, the capacitor must be replaced with one of the same value, if the capacitor is ok, look for a wire with solder on the end but nothing else attached to it, or a solder point on a card with a hole in it or a solder joint that has broken free from the card,,, if you can solder well, and have the equipment,. it is good at this point because You'll need to re-solder them back together,, again a photo will help me greatly in telling you exactly how to fix
2/15/2024 1:40:25 PM • Dewalt Drills • Answered on Feb 15, 2024
Common problems for Dewalt DCR025 JobSite Radio?
Read the reviews. We see them on Fixya very occasionally and from memory, it was internal fuses blowing. https://www.google.com/search?q=Dewalt+DCR025 ..
11/27/2023 7:25:28 PM • Dewalt Drills • Answered on Nov 27, 2023
How do I get a stuck bit out of my DeWalt dc 895?
https://www.youtube.com/watch?v=pNDgV_6k12E Reverse and Forward Mode: Try putting the drill in reverse mode and hit the trigger, then forward mode. If that doesn't work, tap the tip on the driveway but don't slam it. It should release . Use a Wrench: First, make sure that the chuck is in the locked position. Next, use an allen wrench to loosen the set screw on the side of the chuck. Finally, unscrew the drill bit from the chuck . Remove Chuck Collar: Use a wrench or pliers to loosen the chuck collar and remove it from the chuck. Then, use a screwdriver or other tool to remove the chuck jaws and any other components that may be blocking access to the stuck drill bit. Once these components are removed, you should be able to access the drill bit and remove it from the chuck .
10/29/2023 7:06:06 AM • Dewalt Drills • Answered on Oct 29, 2023
Missing component off of Dewalt DCB107 board. Need component ZD1 name
It's going to be a zener diode, that's the easy part, you will need to know the voltage as well, only way to know that is find a good charger and measure the voltage drop across the diode with a multimeter or find a schematic.
8/20/2023 6:20:01 PM • Dewalt Drills • Answered on Aug 20, 2023
Dewalt 18 Volt Dc988 Hammer Drill,dc825 Impact 18v Logo
17 questions posted
Top Dewalt Drills Experts
Sean Wright
Sean Wright
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
View Most Popular
Dewalt Drills
  • Dewalt Drills
Most Popular Question
need repair schematics dc988 dewalt
  • Drills
