20 Most Recent Sony Integrated Stereo Amplifier Amp TA-AX335 Questions & Answers
Search Ebay. They have them.
Sony Integrated... | Answered on Nov 04, 2016
Hi have Sony STR-AV 970 not getting any sound from receiver panel lights up, and the FM
Station is up and running but no sound from either A/B speakers as well as the phones
Sony Audio... | Answered 3 days ago
if all connected correctly check see if fuses inside or outputs could be blown
Sony Audio... | Answered on Dec 18, 2019
Find out why your Sony is in protect mode and repair it to restore normal operation. This is a common problem with Sony equipment and often is traceable to cold or poorly soldered connections.
Sony Audio... | Answered on Dec 17, 2019
Probably the changer mechanism has failed. You will have to disassemble your Sony unit to salvage the discs. As a test, try playing a single disc. You may be able to use your Sony in a limited way.
Sony Audio... | Answered on Dec 15, 2019
Take it apart an on the rear of the display you will see capacitors. You will probably see an end cap that is domed. Just replace them all.
Sony Audio... | Answered on Dec 10, 2019
Try this and let me know. First unplug the unit. Plug it back in. When you first push the power button, you should hear 1 click followed by another withing 5-20 seconds. My guess is that you don't hear the second click. Am I right?
Sony Audio... | Answered on Nov 30, 2019
You have this backwards. Applicable code(s) will be found in the remote control, if it is compatible.
Sony Audio... | Answered on Nov 28, 2019
Applicable code(s) will be found in a compatible remote control.
Sony Integrated Stereo Amplifier Amp TA-AX335 Logo
2 questions posted
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
need stk l r
  • Audio Players & Recorders
