20 Most Recent
Craig Electronics CHT909n Tower Speaker System with FM Radio Questions & Answers
How do I set Craig electronic FM radio, clock and Ipod dock to the ipod dock? It keeps switching between AM radio and clock but not to Ipod?
To set your Craig electronic FM radio, clock, and iPod dock to the iPod dock, you will need to follow these steps:
- Connect your iPod to the dock using the appropriate cable.
- Press the "Mode" button on the radio until the "iPod" option is selected. The display should show "iPod" on the screen.
- Press the "Play/Pause" button on the radio or on the iPod to start playing music from the iPod.
- If the radio keeps switching between AM radio and clock and not to iPod, check the settings to ensure that the iPod is selected as the source.
- Check the connection between the iPod and the dock to ensure that it is secure and properly connected.
- Check the battery level on the iPod and make sure that it has enough power to function.
- If the problem persists, check the user manual for your Craig electronic FM radio, clock, and iPod dock. The manual should have specific instructions for setting the device to play music from the iPod.
- If you do not have a manual, you may be able to find one online by searching for the model number of your device.
- If you are still unable to set the device to play music from the iPod, you may need to contact Craig customer service or a technician for assistance.
What can I do to fix my speaker
If your Craig tower speaker won't turn on or charge correctly, it could be caused by a problem with the battery, the charging port or cable, or a software issue. Here are a few steps you can try to troubleshoot the issue:
- Check the battery level and make sure it is charged. If the battery is low, charge the speaker using the supplied charger or cable.
- Try a different charger or cable to see if the issue is with the charging cord. Make sure the charging cord is not damaged or frayed.
- Check the charging port on the speaker and make sure there is no debris or buildup preventing a proper connection. Clean the port with a soft, dry cloth if necessary.
- Try resetting the speaker by holding down the power button for at least 10 seconds. This will force the speaker to restart and may resolve the issue.
- If the above steps do not resolve the issue, it may be necessary to have the speaker serviced by a professional technician.
How to pair Craig CHT729 speaker to my phone please?
Hey, for the pairing of the Craig CHT729 speaker use these steps:
1: Turn on the speaker.
2: Press and hold the (power) PAIRING button until you hear the voice guidance and the (Bluetooth) indicator begins to flash quickly.
3: Perform the pairing procedure on the Bluetooth source device to detect the speaker.
Or for more instructions search at this link:
Manuals.plus
Will I be contacted after requesting for customer service help?
Question edited for all the typos.
You won't receive any contact from us! We are FIXYA dot com and we are not who you think we are. You need to contact 'them', we are not they.
Just take it back to Walmart, even without a receipt, they will give you a credit note to buy another one. They are budget speaker made in China. Make sure the speaker is fully charged, and replace the battery in the remote.
I need drivers for cmp616f mp3 player
craig cmp616f driver Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Get free help, tips & support from top experts on craig cmp616f driver related ... why isnt my craig mp3 player model number cmp616f turning on? because you need ... ...craig mp3 player cmp616f. how do i turn down volume ? press the volume ...
www.manualslib.com > Brands > Craig Manuals > MP3 Player > CMP616F
View and Download Craig CMP616F user manual online. Craig MP3 Player User Manual. CMP616F MP3 Player pdf manual download.
www.walmart.com/ip/Craig...
MP3-
Player-
CMP616/33846067
Walmart
Rating: 2.5 - 8 votes
Buy Craig 4GB MP3 Player, CMP616 at Walmart.com. ... It looks like you are not signed in. To proceed you will need to either sign in or create a new account.
My windows 10 system does not detect craig 4g8 mp3 player
there are many variables and troubleshooting could be extensive.
1st - insure the ort works with another device.
2nd - look in Device Manager to see if you can find it. If it is under Other Devices with a warning symbol on it, the driver is a problem. If it isn't in Device Manager, the device may have a problem.
3rd - connect to a different port or a different computer.
