20 Most Recent Makita Hm1304bx1 Demolition Hammer + Rotary Hammer Kit Questions & Answers
What kind oil use for makita hm 1304bx1
What kind of oil is used in a Makita Demolition Hammer?
11/3/2015 9:20:47 PM • Makita Hm1304bx1... • Answered on Nov 03, 2015
3answers
Towel caught in front roller
Well, it sounds like you have a belt sander. I would start by sacrificing the towel and the belt. Even if you tried all day and were able to save them they would probably look like they got caught in a sander. Get a utility knife and change the blade, you will want a brand new sharp blade for this. Start by cutting as much of the exposed towel off as you can. Remember, at this point the only thing you might be able to save is the sander. Cutting off the belt will relieve the tension. When you cut the belt give yourself enough belt on ether side to get a good grip. You might need to pull the belt back and forth as you remove small pieces of the towel. A good pair of pliers might help grip the towel fragments. When you finally do remove all the towel and the belt, take some time to look around the drum for fibers that might be stuck in the bearings and pull them out. You may need needle knows pliers for this. Keep the towel shreds for sating rags to finish the project you're working on so it will not be a total waist. Good Luck Ray
2/20/2022 11:42:46 PM • Makita Tools &... • Answered on Feb 20, 2022
2answers
I just used my new Makita 2012NB planer for the first time and the rollers do not grab and move the board even as I lower the cutter head. The board eventually gets stuck and won't budge.
Contact Makita Support direct. This may be a warranty issue. Maker says the Head Clamp is automated.
  • Interna-Lok Automated Head Clamp Feed Mechanism ensures smooth finishes with minimal snipe
https://www.makita.ca/index2.php?event=tool&id=367&from=accessory ..
10/24/2020 10:32:00 PM • Makita Tools &... • Answered on Oct 24, 2020
Makita batterie AH-BMA6MB blinks red and not charging, what is the faults please
Google doesn't seem to be able to find the part number you supplied... Check your instruction book but I believe the flashing red light to mean the intelligent charger is refusing to charge the battery because it has tested it and found it faulty but there is no way of knowing what the fault is. There is a temperature sensor inside the battery and perhaps that has failed the test - or it could be a crystalised cell that has been discharged too long - or it could be the battery is trying to consume too much current - or perhaps it is open circuit and consumes nothing...
10/24/2020 9:27:45 PM • Makita Tools &... • Answered on Oct 24, 2020
Mymakita dbn500 nails and then makes a hole but no nail. Every other time there is no nail, just a hole. Why.
clean ram and check nail slot spring tension
4/23/2020 12:12:52 AM • Makita Tools &... • Answered on Apr 23, 2020
Makita drill overheating
You may need to change the brushes if it is a brushed motor. When you do this you may need to clean the armature with some contact cleaner and a rough cloth to remove and build up of gunk. It's best to change brushes early, as overheating due to wear can cause damage to the armature and brush holders. New brushes are easily found online, and very cheap. See here for a demonstration of how to change brushes. https://www.youtube.com/watch?v=ffXyDqPXCNE
3/27/2019 12:59:58 PM • Makita Tools &... • Answered on Mar 27, 2019
Does the Makita BO5010 need lubrication?
no it does not.
3/25/2019 11:55:56 PM • Makita Tools &... • Answered on Mar 25, 2019
How do I remove the drive belt on a 1inch thickness planer makita model 2012?
Google YouTube its there!
2/3/2019 2:39:18 AM • Makita Tools &... • Answered on Feb 03, 2019
My makita charger keeps playing a tune but not charging
If you are certain your batteries charge on another charger then its time to replace your charger - there are no serviceable parts in it. Or you can sell it as a music box...
2/2/2019 6:55:02 PM • Makita Tools &... • Answered on Feb 02, 2019
Makita 9901 belt sander. How to separate the shell halves so I can replace the cord? I’ve got all the possible obvious bolts removed but something else is holding it. Hidden bolt, clips???
Have a close look for plugs covering hidden screws. Most power tools now have security screws in them to stop people opening them up. You may need to buy a set of special screwdriver bits to get these out.
10/1/2018 3:43:24 AM • Makita Tools &... • Answered on Oct 01, 2018
My Makita Beltsander 9404 is making a lot of noise
you will have to hold arnature and unscrew fan from it. https://www.ereplacementparts.com/makita-9404-belt-sander-parts-c-97_103_535.html
5/30/2018 2:31:24 PM • Makita Tools &... • Answered on May 30, 2018
My makita orbital sander stops spinning when in contact with surface
Damaged gear or overheated motor
3/21/2018 3:16:06 AM • Makita Tools &... • Answered on Mar 21, 2018
Could Makita BO4556 sander be used for wet sanding?
It is insulated, if all your wet sanding will keep the sander motor out of the water I would but that is me. water and electricity don't mix. More details The Most Trusted Makita Palm Sander review
3/15/2018 9:03:14 AM • Makita Tools &... • Answered on Mar 15, 2018
How do I replace the trigger switch on a makita polisher?
See image or google it
10/29/2017 8:01:10 PM • Makita Tools &... • Answered on Oct 29, 2017
0answers
Makita Hm1304bx1 Demolition Hammer + Rotary Hammer Kit Logo
1 questions posted
Top Makita Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Makita Tools & Hardware - Others
Most Popular Question
kind oil use makita hm 1304bx1
  • Tools & Hardware - Others
